Windows 7: X-FI Xtreme Low Sound
05 Aug 2017   #1
Pebble
Windows 7 64-bit
Re-Installed Windows 7 64, Now my sound output seem's about half of what it used to be. Been through all the setting's and cant find anything to get it back like it was.
Followed a link on the Creative support page and installed Windows10/7 drivers. Back to normal now
Creative X-Fi Xtreme Audio plays no sound
Hi, I installed my soundcard, everything works perfect. I installed drivers and i get no trouble at device manager. After I plug my headphones in and try to play music, i get no sound. At the sound options in windows i see the soundcard and it looks like it works, because the green bar goes up...
No sound on Sound Blaster X-Fi Xtreme audio
Hello guys, Last night I was helping to a friend and connected his computer with mine by KVM switch. We had done all, I got unplugged KVM switch,reconnected my monitor,KB an mouse.Everything was just fine. After a while,without reason, (or there may be some reason which I can't figure...
New Diamond Xtreme Sound 7.1/24bit (XS71DDL) - no sound.
I've tried installing and reinstalling and downloading and redownloading the drivers... the BEST I've done is to have loud pops and clicks come from the speakers. * Shut down the computer * Installed card * Plugged speakers into card * Started computer * Disabled onboard sound in the...
Sound Blaster X-Fi Xtreme Audio / Creative.com
Ok, so I read the stickied topic about the X-Fi Xtreme Audio driver, as I think this maybe a part of my computers less-than stable condition after recent Fresh Installs of Windows 7 Home Premium 64bit. I got 2 things... 1) When I install Drivers off my CD, I get a SpiRunE.dll error about a...
Creative Sound Blaster X-Fi Xtreme Audio
Hi, im running windows 7 (7100) 32 bit. Ive got Creative Sound Blaster X-Fi Xtreme Audio in, ive downloaded the xp, vista and 7 beta drivers from creative, they either say driver version not found OR they say the device isnt plugged in properly, which it is having run it with xp. The only thing i...
