Windows 7: Switch between audio output when video output changes
15 Aug 2017   #1
vassock
Windows 7 Ultimate 64bit
I have an ASUS sound card that has SPDIF out via HDMI and also the standard 3.5mm. I want it to either play from both at once or switch when I switch between displays. Is that possible?
15 Aug 2017   #2
fireberd
Widows only allows one default audio playback device, at a time. If an HDMI cable is attached usually Windows will assign HDMI as the default automatically. Thus if I understand your question correctly you can't do what you want.
15 Aug 2017   #3
Lady Fitzgerald
Win 7 Ultimate 64 bit
Actually, he can (unless I misunderstood the OP). I use a small program called Audio Output Switcher to redirect the audio from my 2.1 speaker system to my TV whenever VLC Media Player or Windows Media Player is running.
15 Aug 2017   #4
fireberd
Yes, you can manually switch playback devices. I apparently didn't note that.
15 Aug 2017   #5
Lady Fitzgerald
Actually, Audio Output Switcher can be set to do it automagically based on the program running. I have set on my desktop to switch the audio from my 2.1 speakers to my TV whenever VLC or WMC is running.
15 Aug 2017   #6
vassock
I thought about that already. The issue is that I want to listen on my monitor, too. The best I could come up with is the hotkey toggle method. Oh well.
1 video output playing 2 audio languages simultaneously?
Good afternoon! Just joined this forum in the hope I can find an answer to my problem! I've tried searching online but found no answers so far. This is the issue: I'd like to be able to insert a DVD in my PC and be able to play the video with 2 languages at the same time via different outputs....
Possible to switch audio device output depending on screen/program?
I have my Pc connected to two monitors and a Samsung Tv. The hardware of relevance is this: An Nvidia GPU (560 TI) connected to two 24 inch monitors. HDMI sound disabled. An integrated Intel GPU that is connected the Samsung TV via HDMI (Meaning audio can be sent to the TV together with...
anyway to use hotkeys to switch sound output?
I have my computer hooked up to my tv and I use it with media center. Problem is if I am just sitting at my computer I just use my 3.5mm audio out jack for some desktop speakers, but if I am using my media center I put it through SPDIF out to my 7.1 receiver. Is there a way I can set a hotkey to...
Customization
No audio device output installed, no sound, video game controller...
Normally using my laptop last night. When i opened it this morning. I have no sound and the deadly X red mark on my volume on my lower right screen is present. It is obvious that this problem (no audio output device installed) is very common to many. Reading through hundreds of threads saying i...
How to switch between audio output devices?
Recently got a USB headset, and I have speakers plugged in as well. How do I switch between the two when I want audio to only come from speakers and vice versa? I took this screenshot if it helps: http://puu.sh/FWMO
