Windows 7: Audio plays only from front speakers in 5.1 system/realtek issues
16 Aug 2017   #1
TheSeriousOne
Windows 7 Ultimate -64 bit
Hello,
I have an issue going for 5 days, tried everything I could think of but nothing works, bellow I will write in detail what I tried and whats the detailed issue :
I updated my realtek drivers using the realtek website, after doing this realtek audio manager disappeared from start menu, start bar, control panel and its normal install directory, it vanished, after this happening I clean uninstalled it (removing registry and everything tied to realtek drivers, I used an uninstaller tool for this ) and reinstalled it, same thing, realtek audio manager not present, I performed system restore to 1 day before updating my audio drivers and realtek hd audio manager was there, however when I did the test speakers thing everyting was fine, sound was coming from each speaker and subwoofer but when I tried to listen to music, run apps/games sound was coming only from the front speakers. I tried looking for solutions here from old threads with ppl having the same issue, nothing worked for me, now I reinstalled the lastest drivers once more, same thing with the realtek hd audio manager, it vanished but using the windos playback devices option I was able to configure my audio system, when testing all speakers they work, but same issue is present when I try to listen to music, run games/apps, sound is only coming from the front speakers.
Please help me at least to figure out if its my soundcard (integrated) that cracked, or maybe the audio system motherboard, I dont know, I could try purchasing a soundcard but I would like to be somehow sure it is the soundcard the problem before spending money on it.
If you need anyting (print screens, more specific details please reply and I will try to provide them as promptly as I can).
P.S. : sorry for eventual spelling mistakes.
Thanks in advance,
Andrew
realtek audio pop when audio plays, subwoofer thump
https://rog.asus.com/forum/showthread.php?82320-This-audio-issue-has-to-go-Please-see-for-audio-files The issue: With realtek drivers from either realtek OR the Asus site, I get audio pops/thumps anytime audio is played from idle. Windows navigation's "click" noise turns into a super short...
Front Audio Jacks Don't Work; Realtek Issues
The Specifications Computer type: PC/Desktop Computer Manufacturer/Model Number: Custom Build OS: Windows 7 Ultimate x64 CPU: i7-5820K Motherboard: X99-A Memory: Corsair Vengeance LPX 2x8GB DDR4 Graphics...
Sound Plays in Headphones in front jack but ext speakers do not work
Good Evening Friends, I have had this problem for a long while now but essentially I am forced to use a headphone setup for my desktop but would really like to use external speakers instead of this current set up. What is confusing me is that these external speakers worked for a good long while...
REALTEK|using front speakers through rear output jack - possible?
hi Every time I wanna use speakers instead headphones,I have to use the same headphones output (green one - back panel), and therefor to disconnect and connect cables.. not very comfortable I've tried to use the black output, and it worked, but only as a 'rear speakers', both left and right...
5.1 Channel Audio - Sound only from Front Left and Right Speakers
Dear all, I have been reading 1000s of posts on the net for 5.1 Channel speakers giving outputs only through the front left and right speakers. Well, I am no exception :( - Connected all the cables correctly to the respective jacks... but still... - Tried atleast 5 different of HD Audio...
