No System Sounds. All other sounds working fine.
  1. Posts : 17
    Win 7 64 pro Build 7601
    Have tried EVERY suggested method to make System Sounds work again. Windows 7 64bit Build 7601 on Intel i5 HP Elite CMT with Realtek HD Audio. Microsoft and HP 'troubleshooting' did not find a problem, and yet, there it is. All latest drivers (even downloaded from .cab file from here, but can't get it to install) ... Created new user account - fault the same. Restored System - fault the same ... In 'configure', the speakers play the sounds, but in Volume Mixer, System Sounds show no activity ...
    Do you have system sounds activated, in the Sound Panel?
    Attached Thumbnails Attached Thumbnails No System Sounds. All other sounds working fine.-capture.jpg
  3. Posts : 17
    Thank you for your reply fireberd.
    Yes, System Sounds are activated. Pls see attached screenshot.
  4. Posts : 7,108
    Hi Bigbot,
    IF you are running/have multiple themes, then you have to personalize >>each one<<
    that screenshot only refers to 1 theme,
    Roy
  5. Posts : 17
    I am only using the Default Windows Sound Scheme.
  6. Posts : 7,108
    Hi Bigbot,
    Not Scheme THEME, see my screenshot each one needs to be configured.
    Roy
    Attached Thumbnails Attached Thumbnails No System Sounds. All other sounds working fine.-bigbot.png
  7. Posts : 17
    Like this? ...
  8. Posts : 8,135
    This would appear to be a Windows problem rather than a sound problem.
    Did this ever work? And can you remember what happened, e.g. a Windows update, that caused the problem?
  9. Posts : 7,108
    Hi BigBot,
    thats the place
    If you click on a theme
    then go to the choices at the bottom,
    background/colour/sounds/screensaver
    you can change them to whatever,
    see how mine is different to yours, i chose them for the selected theme
    Roy
  10. Posts : 17
    The difference, is mine shows Sound
    torchwood said:
    Hi Bigbot,
    Roy
