Windows 7: "Realtek HD Audio" or ''High Definition Audio Controller''
06 Nov 2017   #1
w7 64b
I performed a fresh install of windows 7 and updated all drivers/chipsets.
Somehow I feel like my audio is using two kinds of drivers/controllers. See the pictures below.
In the first picture, I suppose that's completely normal, because If i disable one of them, I don't get any audio installed anymore.
In the second picture, If I lower one of them, the main volume gets reduced. I suppose that's also normal, but the thing is when "Realtek HD Audio" is at 100, the sound is completely weird. It sounds like it's playing louder than it should or can. I don't know how I can show you how it sounds, but it's not normal.
tl;dr I can't put volume to maximum because the audio quality gets wrecked and sounds completely not normal. Both of those drivers/devices telling me that they're up to date, so I don't know how to fix it. Edit: for the volume to sound normal, realtek level has to be at 79.
"Realtek HD Audio" or ''High Definition Audio Controller''-screenshot_1.png "Realtek HD Audio" or ''High Definition Audio Controller''-screenshot_2.png
06 Nov 2017   #2
w7 64b
Well, seems I found the issue. It was auto installing a wrong version of realtek HD, hence why the realtek panel was missing. I downloaded the right ones, got my realtek panel and was able to adjust jack settings, setting them to ''headphones'' instead of speakers.
Problem with High Definition Audio - Realtek HD Audio - Code
Hi, I have several computers of differents (HP, Toshiba, etc) and It happens the same problem. The audio device has an exclamation mark in Device Manager. I think this problem is caused by some update windows. My OS is Windows 7 Home Premium 32bits . Does anyone know what Windows Update...
Microsoft High Definition Driver vs Realtek high definition audio driv
Microsoft High Definition Driver vs Realtek high definition audio driver?
Realtek High Definition Audio and Intel Display Audio
I think my question is this: how do I set up VSX-1124 (a Pioneer AVR) in Control Panel/Sound and Hardware/Sound so that its driver is Realtek HD Audio and not the Intel Display Audio one? In Device Manager under Sound, Video and game controllers, I have two sound card drivers, Realtek High...
realtek high definition audio and high definition audio device problem
Hi everyone, I would be very grateful for some help please! My laptop recently installed a BIOS update - I don't know what this was but since it happened I have been having sound problems with my laptop. After the update I had no sound. I read around and found how to get the sound back on - I...
Realtek Driver replaced with "High Definition Audio Device"
Hello. I just recently updated my Lenovo Y530 Ideapad to Windows 7 Ultimate x64 from Windows Vista Home Premium x64. After I updated my laptop, I went to adjust the sound and I noticed that I had 3 sound devices that all said Speakers. I then went to the Device Manager and saw that under the...
