Windows 7: Realtek Audio sound issue
30 Jan 2018   #1
shinhosuck1973
Subwoofer on my pc makes pop sound on power off. I tried different divers but no help. My current Realtek driver is 6.0.1.8186.
30 Jan 2018   #2
fireberd
That is common. Its not the Realtek driver, its a function of how the power is cut off. Either the speaker power supply or the PC power supply.
30 Jan 2018   #3
shinhosuck1973
Thank you for the reply. I am dual booting windows 7 with windows 10. When I power off windows 10, the subwoofer does not make loud pop sound.
30 Jan 2018   #4
fireberd
I still do not think its the Realtek. If anything, its the shutdown process in Win 7. Where in the shutdown process it closes the sound. Similar things can happen during startup, depending on where the sound is activated in the startup.
30 Jan 2018   #5
shinhosuck1973
Is there anything that I could do?
30 Jan 2018   #6
fireberd
You can uninstall the Realtek sound in the device manager (DO NOT uninstall the driver). Then restart the PC and when Windows starts it will detect and reinstall. The MAY put the sound in a different spot in the shutdown sequence and help.
30 Jan 2018   #7
shinhosuck1973
Thank you. I will try that.
01 Feb 2018   #8
shinhosuck1973
I tried, but no help. Thank you though.
No sound in back audio panel jack - Realtek HD Audio Manager
Hello, I have Windows 7 Ultimate 64 bit and I have a problem with sound. When I plug my speakers in front panel I have output audio, but in back panel I don't. :confused: My Audio Manager looks like this, but front panel is enabled and back panel is disabled. It does not recognize back...
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
No Sound - Realtek HD Audio
My last resort though perhaps it should have been the first but I have been all over the web looking for a solution to this problem, the problem being no sound. Where here I am the speaker icon displaying a red cross and when I try to troubleshoot the issue the troubleshooter tells me no speakers...
Quadraphonic sound issue with Realtek HD audio
Hi. I have a problem with the quadraphonic sound in my computer. I've installed Windows 7 RC and the realtek HD audio drivers just yesterday, and when I configure the quadraphonic sound in the Realtek audio manager it seems to work fine. In the tests, the four speakers sound clear, but when I play...
Realtek audio, no sound, need help!
I just installed Windows 7 on my Acer Aspire E380 desktop. I have tried downloading and installing newest drivers, and still am unable to get sound. I have tried uninstalling and reinstalling, still no sound. I have checked in device manager and everything says the driver is working properly. I...
