Windows 7: Creative XFi xtreme audio sound card not supported
02 Feb 2018   #1
lecuenca
window 7 ultimate
Hi, I have the Win 7 Ultimate , but years ago had the win Xp, in that time for that win xp I had bought a Creative XFi xtreme audio sound card.
Now today, have reinstalled in my PC and have downloaded all the new drivers for Win 7 I have foud from creative supported page, but can't have it working.
It gives me an answer that says " This audio device is not detected by this application" or "not supported by this aplication"...
Originally the sond card came with the Win XP drivers..
PLease advise....
Best Regards...
02 Feb 2018   #2
fireberd
The drivers listed on the Creative site include Windows 7. If you are using a separate sound card, any other sound should be disabled (preferably in the BIOS) to avoid conflicts.
Please post a screenshot of the Device Manager, Sound section.
Also a screenshot of the Sound Panel, Playback section.
Screenshots and Files - Upload and Post in Seven Forums - Windows 7 Help Forums
Creative X-Fi Xtreme Audio plays no sound
Hi, I installed my soundcard, everything works perfect. I installed drivers and i get no trouble at device manager. After I plug my headphones in and try to play music, i get no sound. At the sound options in windows i see the soundcard and it looks like it works, because the green bar goes up...
Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit. If you have any idea what can cause the issue please help, if nothing will work i will...
Creative's Sound Blaster X-Fi Xtreme Audio PCI Express
Hey mates, Today I bought and installed a new sound card. Creative's Sound Blaster X-Fi Xtreme Audio PCI Express. More information about the card can be found here: Creative Labs Online Store (Europe) | Sound Blaster | Buy Creative PCI Express X-Fi Xtreme Audio Anyway, this card is a...
Sound Blaster X-Fi Xtreme Audio / Creative.com
Ok, so I read the stickied topic about the X-Fi Xtreme Audio driver, as I think this maybe a part of my computers less-than stable condition after recent Fresh Installs of Windows 7 Home Premium 64bit. I got 2 things... 1) When I install Drivers off my CD, I get a SpiRunE.dll error about a...
Hi, im running windows 7 (7100) 32 bit. Ive got Creative Sound Blaster X-Fi Xtreme Audio in, ive downloaded the xp, vista and 7 beta drivers from creative, they either say driver version not found OR they say the device isnt plugged in properly, which it is having run it with xp. The only thing i...
