Windows 7: Realtek HD audio manager missing playback device in advanced settings
14 Feb 2018   #1
Frikster
Windows 7 64bit
As the title says
When going to the settings of my Asus Realtek HD Audio Manager , i am not able to set different audio to come to different ports, such as one audio to Spekers and different audio to headphones.
https://gyazo.com/d8588aedd0d7af8b330ce3d00b1cd69c
I need this option to play one sound on speakers and the other sound separeted from the speakers to play on headphones but of course both being connected to my PC. I tried a few reinstals but nothing seemed to work and i usually just made it more difficult.
Both devices CAN transmit the same sound if i click on AC97 Front Panel but i have yet to figure out how to play different sounds . . .
Any information regarding this?
Note... i had to install asus realtek manager because anything from their official website made my audio manager ( that window in the screen ) not open up ( more details here : Realtek hd audio manager does not open Solved - Windows 7 Help Forums )
So my question is , can i set up 1 sound to play through the speakers and another sound to play through the headphones. Both devices are connected and labeled as speakers , they are both counted as ONE.
EDIT: I now listen to myself while on microphone. . . So somehow i messed up even more, i have a microphone set up and when talking in it or tapping or whatever i hear it on my speakers. The worst part is, when i disable the microphone in the playback devices it STILL PICKS UP SIGNAL..... the only solution is to disconnect it. Help :|
The last thing i did before having this issue is activate stereo mix, make it as default and click on it to listen to stuff but nothing worked so i turned it off and disabled it back again. Now i hear my microphone EVEN if i disable it or mute it in playback devices.... if i click to listen to it i hear a higher pitched version of me and the lower quiet version of the same voice... basically i hear myself twice ( almost un noticeable since its the same input device.. )
No i dont have another mic set up or internal microphones.
14 Feb 2018   #2
fireberd
First, Windows will only allow one default audio playback device and one source. There may be a 3rd party application that allow what you want to do, but basic Windows does not.
You need to mute the mic in the Recording section, not Playback (If its even listed in playback).
Stereo Mix is usually what is set as default recording device. If you want to record audio from the internet you need stereo mix.
14 Feb 2018   #3
Frikster
Windows 7 64bit
Incorrect.
The microphone was set to listen to itself in the realtek hd audio manager ( which i'm pretty sure i didnt do.. ) so it's fixed now
So about the sound, there is no way to have my headphones register as headphones plugged in on front jack and speakers connected on back jack ?
i'm pretty sure the advanced settings of hd audio manager has those ( as i've seen them in various pictures and examples on google ( Example : http://img.techpowerup.org/080618/HDaudiohelp.jpg ) ... i don't have this, and my realtek does not look like that ... so is it a wrong version or is it "that" 3rd party app you were talking about.
20 Mar 2018   #4
erpster4
Windows 7 SP1 Home Premium 64bit [x64]
what is the hardware ID number of your realtek audio device in your motherboard, Frikster?
example > hardware device ID number on my Hewlett-Packard Pavilion m8417c desktop PC is using "HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_103C2A6C"
24 Apr 2018   #5
erpster4
This is what the Realtek HD Audio manager control panel app looks like on certain (not all) ASUS motherboards like my friend's ASUS M5A78L-M LE/USB3 board (using a Realtek ALC887 audio device with hardware ID "HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_10438576" - speaker setup only but no microphone connected):
Realtek HD audio manager missing playback device in advanced settings-asus-realtek-audio-cpl-m5a78l-m-le-usb3-.png
Missing advanced tab on all items in device manager
I have a strange issue. It seems none of the property screens for devices in my device manager have an advanced tab. I did not check 100% of them but a good portion and things that I know should have advanced tabs like usb controllers and ata/atapi controllers and nic. I noticed this while...
Hardware & Devices
Realtek HD Audio Manager, Buzzing noise in playback
I've got a headset with a mic and In the Audio Manager i've got the playback volume muted. When i un-mute it there is a faint buzzing noise. thats not a big problem but when i want to talk to friends on skype. I'm really quiet and they can hear the buzzing noise. When I try to use the Microphone...
Realtek HD audio manager interface not showing advanced settings
Thank's for looking. I have a Asus-G74sx-91234z laptop,last week when i plugged in headphone i started to hear sound coming from both headphone and the laptop speakers,a quick google search told me change some settings in Realtek HD audio manager,when i opened the user interface i found my realtek...
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
Cannot Realtek HD Audio Manager GUI/settings
After accidentally closing the HD Audio Manager from my taskbar a few days ago, my computer's audio stopped working entirely. So, after researching my problem online a bit, I checked in the Device Manager, and Realtek HD Audio was still installed as an audio driver. Taking the advice of another...
