Windows 7: Monitor audio
14 Mar 2018   #1
Retiredbill
Win7, home premium, 64 bit
Monitor audio
I have had speakers for the audio. I have now taken off the speakers and want to use the speaker in the monitor. How do I turn that on?
15 Mar 2018   #2
fireberd
Depends on what type of monitor/connection you have.
If its HDMI then the audio is through the HDMI connection, if you have that.
If its VGA or DVI type then a separate connection between the Speaker out on the PC and the monitor is required.
All I can say without specifics from you.
 Monitor audio
No audio through monitor speakers via HDMI
I purchased a new monitor and it looks great but I can't get the built-in speakers to function. The monitor has inputs for VGA, DVI, and HDMI and I currently have it connected to my video card via HDMI. The front panel audio jack is functioning and I am able to hear audio if I plug headphones in...
Monitor audio desperation thread
Hey everyone, I made an account here especially to be able to post this thread, which makes me feel like a bit of a leech, but perhaps some of you will be kind enough to help. I've purchased a new desktop computer and a new monitor but I can't get the integrated audio on my monitor to work....
Audio, Dual Monitor, Streaming
Hello all. I recently set up 2 monitors but am having trouble getting audio to go on stream. Realtek surround sound -> fibre optic cable -> tv -> computer via HDMI, computer -> monitor 2 via chord with 2 screws. xsplit and dazzle using virtual audio cable but sound wont capture when i switch to my...
audio wont play on hd tv monitor
I have hooked my pc up to my 32 lcd tv and the picture shows fine but for some reason the audio is still playing out of my laptop i recently formated my pc and before i formated it the audio played through the television when the pc was hooked up to it useing the hdmi cables any suggestion
Music, Pictures & Video
audio goes off and i have to wake monitor to turn on
good morning everybody, excuse me for my bad english, as i'm italian and i don't know exactly the terms for Windows 7 in English.... well, i can't really understand why, as i already set all power saving configuration to "no power saving" , but after a certain period of time, when for example...
