Windows 7: How to automatically switch between default audio devices?
27 Mar 2018   #1
deividhere
Romania
I have an old, but still pretty good Fujitsu computer, with an i7 and all that stuff, and it's connected to a HDMI monitor. So usually, I just use the monitor's speakers as my computer's sound device. But sometimes, I want to listen to my music, and I plug in my headphones, but I need to change the default audio device every time I plug in my headphones, otherwise the monitor's speakers will keep playing. I remember that on Windows 10 I didn't have this problem, it would automatically switch to my headphones whenever I plugged them in. And I can't leave the speakers as the default audio device, as oppose to HDMI audio, because this computer also has an internal speaker that sounds awful. I tried to disable it, but with no luck.
So, my question is: how can I tell Windows to automatically switch between default audio devices when I plug in my headphones?
P.S. The headphones use the 3.5mm jack, and the computer runs a Realtek audio driver.
29 Mar 2018   #2
Gideau
Windows 7 Home Premium, 64b
In case it's impossible, this might be a good second option...
SSD – Set Sound Device
(never tried it, but may do so one day)
How to switch between audio output devices?
Recently got a USB headset, and I have speakers plugged in as well. How do I switch between the two when I want audio to only come from speakers and vice versa? I took this screenshot if it helps: http://puu.sh/FWMO
Quickly switch default audio from speakers to HDMI and visa versa
is there a way to quickly switch default audio from speakers to HDMI and visa versa with one click or even automatically switch to HDMI when displaying to a 'digital television' (or when an HDMI cable is plugged in) and switch back to speakers when displaying to the 'monitor' (or when the cable is...
Is there anyway I can make speakers switch to default automatically?
Hi, I just got Warpia Stream HD VE edition, I got it set up and everything, but I was wondering if I could make it so when it's showing on my TV, it automatically switches over to the TV sound. And when I turn it off, if it could automatically go back to the computers speakers. Is...
One of my audio devices is installed, but not listed as a default dev
So, I have these wireless headphones that I got from Brookstone. The device driver is called E-Core wireless audio. Its installed and ready, but it's not listed as a default playback device in volume control. How to fix? It worked ok before. There's no driver to install on my wireless...
Location Aware Printing - Automatically Switch Default Printers
How to Automatically Switch Default Printers with Location Aware Printing in Windows 7 and Windows 8 Location Aware Printing allows you to set up default printers for each network you use with your laptop or notebook. As you move from one network to another, Windows will automatically switch to...
Tutorials
