Windows 7: Win7 64 bit no exclamation event system sound in programs
16 May 2018   #1
jim78b
Microsoft Windows 7 Professional 64 bit 7601 Multiprocessor Free Service Pack 1
From days sometimes win7 don't play the alarm sound in programs when for ex close an unsaved doc or in autocad when make some Operations. I updates all realtek high Def drivers all sounds works but the alert give me problems is it a bug ?
24 May 2018   #2
iko22
Windows 7 x64, Vista x64, 8.1 smartphone
Check the Windows Sound customisation.
You can Test Windows sound effects from the Sound Window.
You can follow this tutorial if you wish for more help.
24 May 2018   #3
jim78b
Yes I test the win sounds and they work fine .reinstall new audio driver disable nvidia audio and use only realtek .I test all thing at this Point i think is a bug .it happen 1 time yes and one time no ...
16 Aug 2018   #4
GeraldMann
Windows 7 Ultimate x32, Windows 10 x64
Quote   Quote: Originally Posted by jim78b View Post
Facing the same problem in Win 7 32. While testing it works for me everytime, but while working, when it should sound, it doesn't. Strange bug!
16 Aug 2018   #5
jim78b
Ok it is good that happening to you
Shit microsoft
Frequent system hangs, "atapi Event ID 11" in Event Viewer
Hi, I recently made some upgrades to a (previously fine) PC - they were - Installing 4GB extra RAM, of the same variety - Reinstalling windows on a new SSD (a Samsung SSD 850 EVO 500GB) I previously also upgraded to Windows 10, but a bunch of blue screens and other issues later I reinstalled...
Drivers
No sound at all (see event log )
Hello, I am back with a problem that was once before here, but now I have found more evidence of the problem in the events log . The sound works perfect with exterior speakers plugged in, the sound of the laptop alone is completely dead. Also the little sounds you get when starting up and...
One particular System Event sound not playing
As the title mentioned, I have a problem with a single solitary System Event sound. Any event that uses the "Asterisk" event does not provide any audible feedback, that is to say.. it doesn't work. All the other System Events seem to work fine, it's just this one. I've searched and tried many...
Ok To Delete Event Logs of Uninstalled Programs?
Greetings, I just have a question about Event Logs. Is it ok to delete Event Logs or .evtx files of uninstalled programs? The reason I am asking is because as of right now, I am in need of some assistance in trying to solve a problem I've been having in a previous thread that I've posted a few...
Performance & Maintenance
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
