USB 6 Channel 5.1 External Audio Sound Card Issue
  1. Posts : 1
    windows 10 64
    Hello, I bought this: WMA USB 6 Channel 5.1 External Audio Sound Card S/PDIF
    Have installed using driver CM6206LX-1.04(CR), -Windows 10, seems to work fine after install. However, every time I reboot I lose the icon in the hidden tray that enables me to setup speakers etc, and runs this software:
    I have to reinstall to get it back and then change all my audio settings etc again. Then reboot and its gone once more.
    Can you help?
    Did you disable the integrated audio, in the BIOS (F2 Setup)? If not, disable that to avoid any conflict.
    For future, we have a sister Windows 10 forum. Since you have Win 10 register and post there.
    Windows 10 Help Forums
