Windows 7: No audio through bluetooth headphones
21 Jun 2018   #1
MetroBOS
I've owned the same Windows 7 PC for several years, but I never tried using the bluetooth option until today.
I was able to connect a pair of bluetooth phones to it without any problems. They connected, the driver installed automatically, and it said they were ready to use. However, even when the headphones are connected, I get no audio through them (aside from the little "ding" noise that the computer makes when you adjust the volume level).
I've tried going into the "mixer" and changing the device from my Samsung display to the headphones, but that didn't work either. The audio continues to play through my display only.
I even tried connecting a different pair of bluetooth headphones to see if maybe the problem was with the headphones, but those didn't work either.
What can I do to get these things working properly? I'm tired of using wired headphones.
22 Jun 2018   #2
F22 Simpilot
I think you need to change the speaker out to bluetooth under the audio out properties.
22 Jun 2018   #3
Paul Black
7 HP SP1 64-bit Vista HB SP2 32-bit Linux Mint 18.3
Hi MetroBOS,
What have you got the properties set to?
I hope this helps!
Bluetooth headphones issues in Windows 7
So I have had this issue randomly after not using the Bluetooth headphones for a while. I could simply connect it the normal way and everything will connect and all that no issues at all. When I try to work with my music program, my sound has NO BASS. The sound is clear other than that. The...
Headphones Bluetooth pairing but no sound
Hi Guys, Happy New Year! As in the title my Bluetooth headphones pair with my laptop but no sound at all. I tested the headphones with the phone so I know they work. Any ideas? Thanks PS Sorry if I have posted this in the wrong section.
Bluetooth headphones: no sound
I have Bluetooth headphones that I have been using with my desktop Win7 machine successfully for about one year. Now all the sudden without my having changed anything, I get no sound out of them. When I turn them on, Windows recognizes them and shows that they are connected, but when I play...
Hardware & Devices
Bluetooth audio headphones problem - constant stopping
Hi, I'm using Windows 7 RC, and I just bought LG HBS-250 stereo Bluetooth headset. And I'm using kensington bluetooth dongle with windows 7 basic driver. My bluetooth hasn't given me any problem with syncing to my BlackBerry. Now I want to use my headset to listen to music through audio...
Drivers
Bluetooth headphones cut out after about 10 secs
Ok, so after I connect my bluetooth headphones to the computer and start listening to music they cut out and stop working after about 10 or so seconds. Any ideas where i should go with this?
