cannot hear sound
My volume just stopped suddenly here is what I get from the computer
The AMD HDMI Output is not plugged in but the device status is this device is working properly in the general box. In the drive box I can only see driver details, I cannot update driver, roll back driver, disable or uninstall.
I have tried everything I can think of to fix it but failed, Here are the stuff I tried
1) troubleshooting, says it cannot find a problem
2) from the troubleshooting I went to explore additional option then went to recovery that gave no solution
3) Device manager/ right click on AMD high definition audio device then clicked update driver software and restarted that did nothing
4) device manager/ right click on amd high definition audio device then clicked disabled and then clicked enable that did nothing
5) instead of disable in 4 I clicked uninstall and then restart thinking that will reinstall it but that turned up nothing
6) checked all the plugs and they are all connected
7) used recovery manager and that did nothing
Is there anyway to fix this?
