Windows 7: How to Use Virtual Audio Cable
17 Sep 2018   #1
Lady Fitzgerald
Win 7 Ultimate 64 bit
I'm trying to figure out how to use Virtual Audio Cable to take the sound output from Media Monkey and redirect it to VLC player. The directions on Virtual Audio Cable's website are vague and/or outdated at best and I haven't been able to find anything on the web that tells me how to do it.
Getting the sound from Media Monkey (and everything else, which is ok with me) to the virtual cable is easy but I can't figure out how to get it from there into VLC player since VLC doesn't show up on the sound menu.
17 Sep 2018   #2
iko22
Windows 7 x64, Vista x64, 8.1 smartphone
Well, there seems to be several products called "Virtual Audio Cable" out there, I'm unsure as to which one you are referring to.
So then, perhaps I have some hints that you can adapt to your own situation:
i) Had you searched Youtube for an independently made tutorial on this product, or contacted the supplier?
ii) Does the virtual cable that you have created, appear in Windows > Sound.
iii) Have you setup VLC options to stream from this new virtual cable?
17 Sep 2018   #3
Lady Fitzgerald
Quote   Quote: Originally Posted by iko22 View Post
i) Yes. found nothing that helped.
ii) Yes
iii) Yes and no. After I sent my original post, I fiddle-fooled (polite term) around in VLC and finally found, under Media, four selections--Open Disc, Open Network Stream, Open Capture Device, Convert/Save, Stream--that all took me to the same window (can we say redundant?). Under the Capture Device Tab, in Audio Device Name, I finally found "Cable Output (VB-Virtual".
However, there are other selections that have me confused and I need help with (VLC's idiot help wiki says nothing about what they are--mutter, mutter, mumble, mumble). Under Capture Mode, I have a choice of Direct Show, TV-Digital, and Desktop. What the big fat hairy heck is Direct Show? I'm guessing I won't need TV-Digital but what about Desktop? How is it different from Direct Show (and how the heck does one send audio to the desktop)?
At the bottom of the window, there is a button with selections for Enqueue (what on Earth is that?), Play, Stream, and Convert. I would guess Play or Stream would be what I want except there is also tha mysterious Enqueue VLC didn't see fit to define?
Would it kill software developers (not to mention hardware manufacturers) to write complete directions?
17 Sep 2018   #4
badcrc
Windows 7 Pro x64 sp1
Desktop convert records the desktop (a bit like Camtasia), and TV refers to any installed TV tuner card.
17 Sep 2018   #5
iko22
Quote   Quote: Originally Posted by Lady Fitzgerald View Post
I have watched a few videos on virtual audio cable myself, and now I do not believe you can do that.
Let me explain my findings. You can use any application (Media Monkey or VLC, etc) to send audio stream (playback) to an output side of a virtual cable. However, only Recording Applications will appear as receivers (recorders) of this stream from an input side of a virtual cable. Hence, VLC is not showing up as a wave out device because the application is not detected as a recorder.
5 free virtual audio cable software
Difference between Audio Cable and Aux Cable
Hello I have a quick question! what is the difference between Audio Cable and Aux Cable? Is there any difference in sound quality or in Left Right Channel Sound? I'm asking because I recently bought Edifier C2 2.1ch Sound System for my PC that has an External Amplifier that has Aux Input as well....
HDMI Audio issues with cable and gfx card...
Hey guys, first time poster here. I have a palit 9600gso smart 1gb ddr2 card. i recently bought a viewsonic vx-2253mh LED monitor. now i've hooked up my gfx card with my monitor using a hdmi cable but i don't get any sound. i also have a GB GA G41-M-Combo mobo. i was wondering if anyone could...
hdmi cable to LG tv no audio
hi, i have my pc connected to a LG flatron 22" tv by hdmi cable the picture is fine but the audio does not play through the tv, a jack cable from the pc to the tv does not work either, if i use the jack plug into separate speakers it will play the audio through the speakers. i have checked in...
Cable for digital audio out for SB Audigy 2 card
I have a very old but very functional computer that I'd like to connect to my surround sound PC speakers. I currently have the computer connected to the speakers via the analog green, yellow and black cables, but my card states that it can support digital audio out, but I'm not sure what kind of...
Don't know were to put audio cable in hd sound input
I got a Compaq Persario V3000 and I have a Digital Audio (S/PDIF) built in my laptop and I don't know were to put my sound cable. There are two Speakers which I know were to put them but for Digital Audio (S/PDIF) it say it is located in the Rear Panel jack Please help me.I know it...
