Windows 7: Realtek audio, no sound, need help!
25 Nov 2009   #11
reghakr
Windows 7 Pro & Vista Home Premium
When you go to Device Manager,. what shows up under Display adapters?
Is it a WDDM driver?
25 Nov 2009   #12
JimBobby
Quote   Quote: Originally Posted by reghakr View Post
NVIDIA GeForce 8500 GT shows up under it
25 Nov 2009   #13
reghakr
You could always use this fer tool to completely wipe out all video card drivers.
Guru3D - Driver Sweeper
Then run the installation again.
25 Nov 2009   #14
JimBobby
Im not having problems with the video card though, I am having problems with the sound
25 Nov 2009   #15
reghakr
It will be listed under Display adapter in Device Manager,. basically it's a Microsoft driver.
WDDM = Windows Display Driver Model
No sound in back audio panel jack - Realtek HD Audio Manager
Hello, I have Windows 7 Ultimate 64 bit and I have a problem with sound. When I plug my speakers in front panel I have output audio, but in back panel I don't. :confused: My Audio Manager looks like this, but front panel is enabled and back panel is disabled. It does not recognize back...
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
No Sound - Realtek HD Audio
My last resort though perhaps it should have been the first but I have been all over the web looking for a solution to this problem, the problem being no sound. Where here I am the speaker icon displaying a red cross and when I try to troubleshoot the issue the troubleshooter tells me no speakers...
Realtek Audio Windows 7 No Sound
I just reinstalled windows and installed the latest realtek from here Realtek I checked my playback devices, and it shows a green bar going up and down indicating that the sound should be working, but i can't here jack. If i switch my sound in playback devices to my 42 inch flat screen,...
Realtek HD Audio Sound Comes and Goes
My sound comes and goes on my HP e9280t. Sometimes I get the realtek hd manager icon telling me that the speakers have been plugged in, and then 1 second later it tells me they have been unplugged. It can keep doing that for minutes until I finally close the message. If I go into the audio manager,...
Hardware & Devices
