CPU usage and audio
  1. Posts : 179
    Windows 7 Professional
    CPU usage and audio
    I have quad-core computer. When listening to MP3s with Windows Audio Player and no other programs running, the CPU Usage monitor shows 10-12% usage. I have an on-board audio card.
    Would a dedicated audio card take some of the load off of the CPU?
  2. Posts : 28,845
    Win 8 Release candidate 8400
    Probably not. Is 10-12% a problem?
  3. Posts : 6,857
    That does seem a little high. I just tried it, with my wallpaper slideshow running to switcxh every 3 minutes, 5 tabs open in Firefox 3.6, and WMP playing an mp3 song, my CPU is fluctuationg from 0-3%, and I only have a dual-core.
    However, zigzag brings up a good question....is that really a problem?
  4. Posts : 908
    Windows 7 Home Premium
    Like others... I'm only showing a 0-2% use playing an mp3 using either Windows Media Player or Winamp.
    Since you're using Windows Media Player I can think of two separate "enhancements" that might use CPU.
    1. Visualizations can use considerable CPU, Alchemy-Random can suck up 15% of my CPU's resources.
    2. Audio Enhancements. Check and see if you have any of WMP's audio effects active. Both "graphic equalizer" and "SRS WOW FX" can use CPU as can changing the play speed.
    Ap
  5. Posts : 179
    You guys are right, to an extent. CPU usage starts out low (0-2%). After I turn on a visualization, the CPU usage goes up and it doesn't go back down after I go back to the normal view. Odd! As for Audio enhancements, I can never find the controls for those when I need them and have given up. It was much easier in the previous versions of Windows Media Player.
  6. Posts : 908
    If you have Media Player opening in Library mode, click on the small icon in the lower right, this sets media player to "Now Playing". Right click in the top Window border and you should see a menu with several selections, "Enhancements" is midway down.
    Ap
  7. whs
    Enhancements can take a lot of CPU power. Just set "Disable all sound effects" for a test.
  8. Posts : 179
    [QUOTE=Aphelion;624885]
    Why can't I do that from Library mode? Makes no sense.
  9. Posts : 908
    [QUOTE=Cluent;625102]
    Yet another Microsoft Mystery "Feature".....
    Ap
  10. Posts : 179
    So would a dedicated sound card take over the Wow effects and reduce CPU usage?
