VB Audio Virtual Audio Cable Input and Out put mixed up
  1. Posts : 2
    Windows 7 Professional
    Hello.
    At the moment my only "pair" of headphones has only one working speaker (the other is missing!), so I've been using VB Audio Virtual Audio Cable to combine both channels and play them through the left earpiece. Recently, though, I fell for one of those stupid driver updater scams, which installed that annoying RealTek bloatware, and I'm not sure if it was then or some time afterwards that this happened.
    My output is where my input should be and vice versa. I can't find anything relevant elsewhere, so I decided to post here. Any suggestions? Thanks in advance.
  2. Posts : 2,798
    Windows 7 x64, Vista x64, 8.1 smartphone
    You'd best start out and create a new Virtual Audio Cable. Rather than edit/delete the VAC you already have.
    Here, I used this video 2 months ago. https://www.bing.com/videos/search The explanation is crystal clear. He is using skype and teamtalk, but you can adjust for your own microphone.
  3. Posts : 2
    Sorry, but that's irrelevant. :(
    Sorry for the super-late reply, but I'm using the VB Audio Virtual Audio Cable at
    VB-Audio Virtual Apps
    not the one in the video, so that doesn't help. Happy Thanksgiving, though.
