Help! Static/garbled voice when using microphone for voice chat
Hello! I am having trouble with a strange static/garbled voice issue on Windows 7 Home Premium. My apologies for the long post, but if I leave something out, it will make it harder to find the problem.
First, system specs:
Home built system
Asus M5A99X Evo R2.0
AMD FX4350 Black Edition
8 gig Patriot RAM
AMD Gigabyte RX550
Asus Xonar AE sound card, using Asus Sonic Studio program
Two 1TB WD internal drives
One 1 TB Seagate internal drive
One 2TB WD My Passport
Win 7 Home Premium – just reinstalled this week.
All drivers up to date
BIOS version 2501
Antec HCG 750 power supply
Antec Kuhler CPU cooler
Logitech headphones
Enermax Ostrog case
The problem started several weeks ago. My Realtek onboard sound quit working. I went through everything I could to find out why it didn't work, but it is no longer being recognized by the system. I bought a new sound card, an Asus Strix Soar. It worked for a while, then I moved the card from the lowest slot, the PCIe slot at the bottom, which can be used for PCIe x4 and so on. I put it in the 2nd PCIe slot just below the graphics card, in order to help keep it cooler (was just above the power supply, which is on the bottom of the case). I had not noticed any issues when it was on the bottom, but I had not ran it that long, either. I was talking to someone on Teamspeak voice comms, when they said my voice started sounding like I was on helium, and was full of static noise. At that time I could not get the sound any better. Just FYI, I have not been able to reinstall the card in the lowest slot, because it does not seem to work there anymore. I get fatal errors, and I think it may be because I can't get the card completely seated in the slot. I am left with only the one remaining PCIe slot. The small slot above the video card is blocked by the card.
I tried another headset the next day, and the problem reoccurred, so I know it was not the headset. I contacted Asus support to tell them about the problem. I explained that the problem was intermittent, that if I unplugged the headphones and replugged, it would go away for a while, then come back. They stated that it sounded like the card was bad. I returned the card, and purchased another Asus card, a Xonar AE. I uninstalled the drivers, and tried this one. It also worked for a while, but then the problem would start again.
In the process of testing this, I uninstalled the latest driver, 1.1.17, and tried the version on the install disk, 1.1.12. Problem still occurred, so I decided to go back to the other driver. I uninstalled, and then the whole system crashed. Would not read Master Boot Program, could not find it. After multiple attempts to fix it, which failed, and going through a system restore, which did the restore but still would not fix the boot issue, I had to do a reinstall.
Luckily, I had been experimenting with Linux Mint on a flash drive, and was able to run that OS, see all the files, and move/copy them to my other drives.
I had to completely blow away all partitions on the drive, and start fresh, in order to get the install to work. I had to go in through the command prompt to clean the drive, because nothing else would work.
I finally got the install done, reinstalled the sound card drivers, Teamspeak, Discord, etc. As before, things worked well for a while, then the problem started again. I started doing more testing to see why this was happening. I tried running Discord again, to see if the problem would reoccur. It did after awhile, probably about an hour. Once it started, I unplugged the mic, and the problem went away. When it came back, I shut Discord down, started it back up, and it worked for a little while, then the problem happened again. The difference was that I had not unplugged the mic this time, and the problem went away after I closed the program. I also ran TS to see if it might be something to do with the keyboard. The problem happened first with Discord, without having to key the mic, so I don't think it has anything to do with the keyboard. I took an audio clip of the sound, which I am posting here for you to listen to. The first voice you hear is mine, then you hear the garbled voice next due to the transmit delay. I intend to post another with only the static the next time it occurs.
Dropbox - Voice 006.m4a
This sounds like an electrical issue, like an unfiltered signal. When I shut off Discord, and restart, it goes away, and then comes back. I also tested to see if it might affect regular audio, like a sound file on You Tube. It did not...it only affected the mic circuit.
At this point, could we be looking at a power supply issue? Seems like if it was the board, it would do it all the time.
I have been updating Asus support, who is looking into the issue,
I will post more information as I have it.
Thank you for taking the time to read this.
Jim
