Windows 7: Suddenly no sound. "Failed to play test sound" Is this unsolvable?
18 Jan 2019   #11
wither 2
Windows 7 Pro SP1 64 bit
I was going to suggest something else but-
You said you don't have any restore points. However, Windows creates a restore point every time it does updates. I see in the log that you did install updates in early January. Would you check again?
18 Jan 2019   #12
dinki
I went to 'Backup and Restore' and it tells me that backup has not been set up. I'm open to exploring this further but it seems like I have no backups.
While here I did see the 'Create a system repair disc'. Does that create something I could use or is that something that needs to be run before a problem exists?
18 Jan 2019   #13
iko22
Windows 7 x64, Vista x64, 8.1 smartphone
I think the correct procedure is to create a system repair disc BEFORE the problem occurs. That is, I cannot find any information that says you can create such a disk AFTERWARDS.
If it is any consolation, you can use a system repair disc that has created on any Windows 7 computer, so long as it has the same bit-ness.
18 Jan 2019   #14
wither 2
Quote   Quote: Originally Posted by dinki View Post
In Control Panel, click on System. Select System Protection. In the System Restore section, click on System Restore. Any restore points should be listed there.
18 Jan 2019   #15
dinki
Quote   Quote: Originally Posted by iko22 2 View Post
1 Hour Ago 10:29
Yeah, if you look at my original post:
  • Booted Win 7 install disc. Chose 'Repair PC'. Windows said it found problems but couldn't fix it.
That said, I have done a few things like cleaning up the registry and such so maybe I'll try the
18 Jan 2019   #16
dinki
Quote   Quote: Originally Posted by wither 2 View Post
Yeah, nothing there ...
18 Jan 2019   #17
wither 2
That's strange. The one it set for me when I installed the last set of updates is listed there. When you clicked on system restore, did the screen for Restore system files and settings come up? If so, did you click on Next?
No Sound /Failed to play test tone
Hi Fellas, Ok so the problem started with some corruptions in 'mountmgr.sys' after successfully repairing Windows i was able to boot again and everything seemed to work just fine (incl audio) until the next day when i boot my system the Audio wont work at all! No external Audio Card installed, i...
"Failed to Play Test Tone" aka Poisoned USB Ports
Here's one for you. Running Win7Pro x64. I have a cheap USB sound card (7.1 channel sound), which works fine using Windows sound drivers. It works with any other computer too, and works with my laptop *UNLESS* it's plugged into particular USB ports on my hub. These two particular USB ports...
Sound Won't Work "Error failed to play test tone"
Hi. I have had some problems recently with my PC, and the latest is that my sound doesn't work. I have Realtek HD Audio. I can still see my speakers under the Sound list in Control Panel, and they say they work. All of my drivers are up to date and say they work. I have tried many things,...
"Device Failed to Connect" sound notification
Hi, Whenever the desktop appears I get the sound "dududu" with no popup. Please help.
Drivers
"Device failed to connect" sound plays randomly
Hi. This my first time posting here, but I've visited these forums on several occasions in the past to solve various problems, so hopefully someone will be able to help with mine:). My parents and I moved into a new house on the 25th of April, and I got my desktop computer hooked up a few days...
Hardware & Devices
