Windows 7: Sound card question on "what you hear"
3 Weeks Ago   #1
F22 Simpilot
I want to purchase the Creative Labs Sound Blaster Z 30SB150200000 listed here.
I can't find any information on whether it has the capability to listen to the "what you hear" option. Anyone know if this card supports that feature?
3 Weeks Ago   #2
badcrc
Windows 7 Pro x64 sp1
I've got this Soundblaster Z (on Windows 10), and it has a slider 'what you hear'.
(there was a lot more sliders until I disabled the onboard audio)
I got the SBZ to use with Cubase - to get low latency when I play my MIDI keyboard. I also like the on-card headphone amp, switchable from the control panel. I use the eq, but all the other bells n whistles effects are just rubbish IMHO - although they may work with game sounds (I'm not a gamer).
Not the exact same SBZ, bit HTH.
3 Weeks Ago   #3
F22 Simpilot
Then that sounds (no pun intended) promising. I can pick this card up on eBay for $40. He's got 10 or over 10.
So you're saying your card isn't the exact Z model as I have indicated? I did ask the seller, but he said, "I believe it has the what you hear option." So I had to ask here to confirm. I really don't want to have to make a return if it doesn't, and matter of fact I probably couldn't based on that criteria using eBay. If I bought it out right at full price on Amazon it be a different story.
Edit-
Okay, I see now you added a link there for yours. I can only imagine that I suppose the Z model I'm interested in has the option I'm looking for. I really hope. I'll ask the seller if I can make a return if it doesn't.
SD card reader works but no "removal of hardware" sound or icon
I have an Asus CM1630 desktop running windows 7, 64 bit. SD card reader works, after adding drive letter, but there is no hardware removal or insertion tone and the is no icon to safely remove the SD card. The SD card works fine when placed in an USB adapter and plugged into the USB port - there is...
Hardware & Devices
"Stereo Mix" to record sound from card missing.
Im trying to playback audio for sstv through my sound card and the "Stereo Mix" option is missing as an audio input (recording) method. I have some in-product sound card that came from Dell so I've been told it may not be possible. But I've found free software that does record in the same exact way...
Connecting "HD audio" cable from front panel to sound card
My sound card Xonar D1 doesn't work properly and i wrote to ASUS and they told me to connect the "HD audio" or "speaker" cables from the front panel of motherboard to the sound card's front panel. Is that safe to do? weather it will work or not, is it safe to try?
"HD Audio" drivers keep installing - disabling my recording sound card
My motherboard has on board audio which I disabled in my bios in order to use my recording sound card. This worked flawlessly for over 2 years. Then sometime last year Windows installed my "Missing HD Audio Driver" which disabled all sound until i enabled the on board sound in the bios again,...
"Change Sound Card Settings" Question
Hello, I do a fair amount of changing the Default and selecting the sound card that I use for various programs. If I do a search with "sound," the Change Soundcard Settings option appears. I click on it, and get the small screen that allows one to pick the cards for Playback, Recordings,...
