Can't record my line in sound, using USB sound device and windows 7
  1. Posts : 3
    Windows 7 build 7000
    I've had this problem since windows vista, in windows xp i could record my line in perfectly, without any problems, but now, even if i enabled Stereo mix(tried mono also) it won't make any sound when i try playing some music.
    Anyony that can help me with this?
    Also, as stated in the title, i'm using an USB sound card device.
  2. Posts : 436
    Windows 7 Build 7048 x64
    Hi Coolman12 and welcome to the forum!
    I did some digging regarding your Zalman ZM-RSSC, unfortunately zalman never released vista driver support for it. If you were able to make it work for Vista, you're chances to make it work for Windows 7, that pretty much tells you that you're out of luck
    But there's probably one thing you might be able to do to make it work. Please try the Windows 7 Driver solution. It could be worth a shot.
    Cheers
  3. Posts : 3
    I never got it working in vista, i'm sorry if i made you think so :)
    It has never worked after windows xp
  4. Posts : 436
    Oh, I apologize for the confusion. It was a statement and not an assumption. To put it simply, if it ran on Vista you have a very high chance in making it work in Windows 7 :)
    Please do give DriverMax a spin, just follow the link in my first post
  5. Posts : 3
    I am as we speak :)
