Digital Audio S/PDIF Problem
  1. Posts : 5
    Windows 7 Ultimate x32
    I have a problem with audio, after upgrading to windows 7 Ultimate 32 bit, I installed all the drivers that are neccessary for windows 7. My audio device is High Definition audio device but the only device I can see is Digital audio S/PDIF. Other devices that may be disabled don't appear. I installed all of the Realtek drivers for on board audio device. and I tried installing several others aswell but with no luck. I tried all of the solutions that I was able to find online and nothing works.
    When I install Realtek driver, it won't show up in my device manager, or sound (only Digital audio), when I run troubleshoot compatibility on any Realtek drivers it detects that the driver is not compatible with my system. I uninstalled my driver that automatically installs on every boot and then I disabled the automatic driver install, and I disabled automatic updates to prevent auto install of the driver that clearly doesn't work. but on the next boot the driver automatically installs again.
    The audio doesn't work when I plug my speakers in any port and I dont have front jack on this PC.
    my hardware ID of HD audio device is
    HDAUDIO\FUNC_01&VEN_11D4&DEV_1986&SUBSYS_1043818F&REV_1005
    Manufacter:ASUSTeK P5L-MX
    Audio adapter: Intel 82801GB ICH7 - High Definition Audio [A1]
    I totally ran out of ideas, it's 4 days that I'm trying to find a solution to the problem. Any help is appreciated.
  2. Posts : 278
    Windows 7 Home Premium (64 bit)
    click this link P5L-MX Driver & Tools | Motherboards | ASUS USA
    Choose Vista 32 bit, scroll down to AUDIO, download driver.
    Here is 7zip, it will allow you to open the archive. 7z1900-x64.zip
    Once extracted, open folder created, open 6400, run setup.......that should do it.
  3. Posts : 5
    Thank you so much man, you are the best <3
  4. Posts : 278
    Welcome
  5. Posts : 496
    Windows 7 SP1 Home Premium 64bit [x64]
    kristinarapida said:
    I had the same problem.
    what kind of computer or motherboard are you using, kristinarapida?
    OP's problem was due to installing the wrong driver. OP's ASUS P5L-MX board does not use Realtek audio drivers as the board uses ADI SoundMax HD audio hardware and needs ADI SoundMax audio drivers.
