Windows 7: Digital Audio S/PDIF Problem
02 Apr 2019   #1
DoryIonut
Windows 7 Ultimate x32
I have a problem with audio, after upgrading to windows 7 Ultimate 32 bit, I installed all the drivers that are neccessary for windows 7. My audio device is High Definition audio device but the only device I can see is Digital audio S/PDIF. Other devices that may be disabled don't appear. I installed all of the Realtek drivers for on board audio device. and I tried installing several others aswell but with no luck. I tried all of the solutions that I was able to find online and nothing works.
When I install Realtek driver, it won't show up in my device manager, or sound (only Digital audio), when I run troubleshoot compatibility on any Realtek drivers it detects that the driver is not compatible with my system. I uninstalled my driver that automatically installs on every boot and then I disabled the automatic driver install, and I disabled automatic updates to prevent auto install of the driver that clearly doesn't work. but on the next boot the driver automatically installs again.
The audio doesn't work when I plug my speakers in any port and I dont have front jack on this PC.
my hardware ID of HD audio device is
HDAUDIO\FUNC_01&VEN_11D4&DEV_1986&SUBSYS_1043818F&REV_1005
Manufacter:ASUSTeK P5L-MX
Audio adapter: Intel 82801GB ICH7 - High Definition Audio [A1]
I totally ran out of ideas, it's 4 days that I'm trying to find a solution to the problem. Any help is appreciated.
02 Apr 2019   #2
gldndragn
Windows 7 Home Premium (64 bit)
click this link P5L-MX Driver & Tools | Motherboards | ASUS USA
Choose Vista 32 bit, scroll down to AUDIO, download driver.
Here is 7zip, it will allow you to open the archive. 7z1900-x64.zip
Once extracted, open folder created, open 6400, run setup.......that should do it.
03 Apr 2019   #3
DoryIonut
Thank you so much man, you are the best <3
03 Apr 2019   #4
gldndragn
Welcome
18 Apr 2019   #5
kristinarapida
I had the same problem.
1 Week Ago   #6
erpster4
Windows 7 SP1 Home Premium 64bit [x64]
Quote   Quote: Originally Posted by kristinarapida View Post
what kind of computer or motherboard are you using, kristinarapida?
OP's problem was due to installing the wrong driver. OP's ASUS P5L-MX board does not use Realtek audio drivers as the board uses ADI SoundMax HD audio hardware and needs ADI SoundMax audio drivers.
Digital Audio S/PDIF problem
So guys,I havent been turning on my pc(using win 7) for like a month,when i did it was saying Digital Audio S/PDIF and no sound was going nor through speakers nor through headphones.Before that everything was working fine.So,since i had some viruses on it i reinstalled win,formated both...
Digital Audio (S/PDIF) isn't playing sound.
My computer died recently, so I dug out some fossil from way back to at least listen to music/watch some movies until I can buy a new one(Which won't be anytime soon). I hooked up the HDD from the dead PC to this one and everything is working OK(all things considered). However, I can't seem to be...
VIA High Definition Audio ,no sound digital audio (S/PDIF)
Motherboard :asus p5kpl-am se (no sound card) vendor id :1106 device id :0397 problem: digital audio (S/PDIF) no sound OS : Windows 7 ultimate 32bit i've download numerous latest driver on the official website of VIA and installed it, yet no different.. i wonder if anybody can help me with...
How does S/PDIF Digital Audio work?
Hey, I was wondering how the hell does S/PDIF Digital Audio work and how does it remember exactly what % volume it should be on a motherboard? I don't have any speakers, just a keyboard and mouse and I've, reset BIOS, reformatted and reinstalled windows 7 disc and the S/PDIF still remembers what...
Digital Audio (S/PDIF) Making a Digital Sound with Internet Surfing?
Hi, I've recently switched to Digital Audio (S/PDIF) (High Definition Audio Device) using one Toslink cable instead of all the analog wires going from my PC to my receiver. The digital sound is amazing, CD quality from my PC is great. However, I now also receive the digitized sound of...
Twitter Facebook
