Windows 7: Intermittent no sound
22 Apr 2019   #11
muffiemaqe
Win 7 Pro 64-bit
Thanks for your ideas about the Network Controller. As for the sound, I have marked the issue "problem solved."
22 Apr 2019   #12
wither 2
Windows 7 Pro SP1 64 bit
What solved your sound issue?
22 Apr 2019   #13
muffiemaqe
Win 7 Pro 64-bit
I'm not sure, but I solved it myself. I finally discovered that the speakers were not set to default, even though I had set them to default. Windows sometimes changes things without my instruction.
05 May 2019   #14
RoWin7
Win 7 Ultimate 64-bit
doo-doo doo-doo, doo-doo doo-doo
You're traveling through another dimension, a dimension not only of sight and sound but of mind. A journey into a wondrous land whose boundaries are that of imagination. That's the signpost up ahead - your next stop, the Twilight Zone!
19 May 2019   #15
gdawg65
Windows 7 Home Premium 32bit
I had similar problem in windows 7 Pro. Sometimes the sound worked and sometimes it didn't. I found that if I selected 'sleep' and then woke it up, the sound was fine. I don't why it works but it does.
Intermittent distorted audio with Nvidia HD Sound.
Hi there, recently I've started noticing that when I'm using the Nvidia HD audio most times when I either start up a program or switch tabs on Chrome my audio distorts and gets slow, this happens across all audio platforms (iTunes, YouTube etc). It's driving me nuts and I'd like to try and find...
Sound Intermittent
Hi all I have a ASUS DGX 5.1 sound card. When I play music or play any game I get the same. The music or games I play sounds if they are underwater in a echoey tunnel wind tunnel. I have tried 2 different sound cards and headphones but get the same. I have updated all the drivers on my system....
Intermittent sound on new installaton with new mobo
Hi all, Last weekend I upgrade my computer with a new mobo as well as a new case. This case front panel jacks for headphones and a microphone, which is the main reason why I bought it. Case : CoolerMaster 690 USB 3.0 edition MOBO : Asus M5A97 R2.0 The case and mobo offered two choice for...
intermittent sound output :s
Hi all, so I've been trying to figure out what's going on with this acer 5520 amd 2ghz, 3gb laptop. Basically this is what I've checked and done: drivers updated, bios updated/re installed re seated all internal components I.e: cd drive, ram, hdd . Fresh install of vista, win 7 and finally xp...
Intermittent sound problems x64
hi all, I built a pc for someone and they are experiencing sound problems, the problem I have it that it doesnt act up on me. So here are the symptoms. While listening to something the sound will start breaking up and then completely stop. After reboot it works fine. I just want a proper...
Twitter Facebook
