Windows 7: Sound Issues with USB Audio CODEC device
1 Week Ago   #1
chriswaggoner
I am not using the Realtek soundcard that's in my computer case. I am using an external, USB soundcard which did not come with drivers. It is a "plug and play" device. On my Windows 7 computer, it is, by default, referred to as "USB Audio CODEC".
The setup worked perfectly up until yesterday. Since then, the device has been visually appearing okay. The computer detects it and everything. However, when I try to create a "ding" sound with the volume bar on the Windows 7 taskbar, that ding abruptly cuts off, and it only works once after I click the volume bar multiple times. The sound device is still shown to be detected and working, but the green levels that appear no longer do, which means not even Windows is receiving those signals anymore.
Windows Media Player does not launch at all, and YouTube videos play without any sound.
In order to ensure that the hardware's fine, I tried using it with my XBOX, and the sound was perfectly fine, like it always used to be. I also tried unplugging and replugging the USB hub which connects this USB soundcard to the computer, and also tried doing the same with the soundcard itself. I even tried using different ports on the hub, and soon afterwards, used different ports on the computer case itself. The result has been the same so far.
I also manually uninstalled the USB audio CODEC through "Device Manager" multiple times, then reconnected the USB soundcard. The driver reinstalled itself perfectly, but the sound issues remain.
Does anyone have any advice or solution? Thanks a lot in advance, much love!
5 Days Ago   #2
Paul Black
[1] Win 7 HP SP1 64-bit [2] Vista HB SP2 32-bit [3] Linux Mint 18.3
Hi chriswaggoner,
Welcome to SevenForums!
Quote   Quote: Originally Posted by chriswaggoner View Post
I notice that you haven't had an answer for your issue.
Do these help =>
USB Audio Codec Installation Guide - Windows 7.
Seven quick fixes to get audio working again.
NO sound, Audio Codec/Audioess.dll files corrupted after SFC Scan
Hello, I recently updated a Windows 7 service pack and while it was updating, I opened GeForce Experience to see if there was an update for my graphics driver. When I did this, my PC crashed and after it booted up, I've had no sound ever since. I've done everything I can think of. Ran scans, an...
Can no longer find "USB Audio Codec" when device plugged in
When I right click on the tray speaker icon and select the sound window, I can no longer find the "USB Audio Codec" selection when the device is correctly plugged in. The USB device still works because I can test it on another computer. It is present in the devices and printers window. Software...
Sound problems using VIA VT1708S 8-channel High-Definition Audio Codec
Hello. When i try to run Insane 2 (in2ane) and Lord of the rings War in the north on my Windows 7 Ultimate x64 I hear no sound from the mentioned sound codec.If I try to run GTA 4 or any other game it works very fine.So...Is there a fix for this?Can someone help me?
No Audio Output device is installed! no sound! :(
Hello everyone, i have seen this posted before but my problem is a little different. I can not even find what my sound card is or where it is. I have looked and looked and there is nothing on my computer to show it has a sound card. It did indeed work before i upgraded to 7 so it has to be there....
Poor low Rear sound - ALC890 Audio Codec
I have a 4.1 creative sound system and i can barelly hear the rear speakers , i can only adjust the DB Room Adjustment of the speakers if im in 5.1 OR 7.1 mode. Even then its not great :cry: Why though not QUAD enable toom adjustment? , seems stupid to me :huh: Also there is alot of annoying...
Twitter Facebook
