Need help recovering device disconnect sound feature
  1. Posts : 1,606
    Windows `10 Professional 64bit
    Windows 7 Pro
    I know this may sound silly but the choice of device disconnect sound is missing from my Control Panel.
    It is on my other computers.
    Wonder if anyone can suggest a way to put it back short of reinstalling Windows?
    I like it for when I disconnect an external USB drive.
    Thanks for reading this.
    Attached Thumbnails Attached Thumbnails Need help recovering device disconnect sound feature-disconnect.jpg
  2. Posts : 3,615
    Hi jadinolf,
    I don't, but are you aware of Repair Install - Windows 7 Help Forums
    Run from within windows, replaces your OS, keeps everything else!
    Also known as In-Place-Upgrade.
    Repair Install to Fix Windows 7 Without Reformatting by Britec
  3. Posts : 1,606
    Snick said:
    Hi jadinolf,
    Thank you. Never thought of it.
    I'll give it a try and get back to you.
  4. Posts : 3,615
    Try DISM++ for updates, shows problem ones in orange, you can pick and choose what to install, no restart till your finished.
    DISM++ Website
    DISM++ Direct Download
  5. Posts : 1,606
    I'm trying to be sure I have Windows 7 pro.
    The Windows DVD says my version is not compatible with the DVD.
    Can't believe it.
  6. Posts : 1,606
    DISM++ Website
    Will do.
    Nothing seems to be going right in the MINOR (?) project.
  7. Posts : 1,606
    DISM++ Website
    Nope - no help BUT it did confirm what I already knew. It is Windows 7 Pro.
    I'm gonna knock if off here but I thank you for the help and a new program to play with .
  8. Posts : 2,798
    Windows 7 x64, Vista x64, 8.1 smartphone
    Is the problem because you have set a custom Sound Scheme? Maybe the default Sound Scheme will bring the list up again.
    Also worth a check. Look in \Windows\media directory for the presence of a "Hardware Remove" sound file.
  9. Posts : 1,606
    I'll give it a try BUT the same scheme in on all five of my computer have a sort of custom scheme and they have a requirement for disconnect USB device.
    I have come to believe that the missing thing is not worth worrying about.
    Thanks for checking in.
