Sound Effects
  1. Posts : 50
    Sound Effects
    Hello,
    For DRM Audio the Audio Manager (AM) contains the Sound folder for sound effects, which in my case is empty.
    Whenever files transferred/deleted etc. no sound.
    Otherwise the AM functionality is unaffected.
    How do I regain the full functionality, including the sound effects?
    Thank you
    barsim
    Attached Thumbnails Attached Thumbnails Sound Effects-bin1.jpg   Sound Effects-bin2.jpg
  2. Posts : 6,021
    Win 7 HP SP1 64-bit Vista HB SP2 32-bit Linux Mint 18.3
    Hi barsim,
    I see that you have found a solution [as you have marked the thread as solved] to your problem/issue/question. Can you please post the solution so that other people visiting this thread can benefit and learn from your experience.
    Thank you!
  3. Posts : 50
    Hi Paul,
    The solution is very simple: the new AM did away with the Sound folder that contains the effect files, later the Audible. com (Amazon company) removed the older users' sound effect files, leaving the Sound folder in place.
    barsim
  4. Posts : 6,021
  5. Posts : 50
    barsim said:
    Hi Paul,
    barsim
    This is a proven solution: Download the new AM, Apps for Listening to Audible Audiobooks | Audible.com, in the Edit/Option enable Sondeffects, if they are missing Download them, too.
    barsim
