Windows 7: Headphones not being recognised on re-connection.
3 Weeks Ago   #21
Paul Black
Win 7 HP SP1 64-bit Vista HB SP2 32-bit Linux Mint 18.3
Hi davethurston,
Check the Playback Devices under Sound Properties and make sure that it is set as the default playback device.
Click Start => Control Panel => Sound => Playback Devices tab.
3 Weeks Ago   #22
davethurston
Microsoft Windows 7 Professional 32-bit 7601 Multiprocessor Free Service Pack 1
after downloading the two files from the sociologness site, malwarebytes detected 146 threats and windows defender found two viruses. i don't think i'll go near that site again.
in terms of playback devices, the loudspeaker is (as it always has been) the default device. no mention as always of headphones as a device
3 Weeks Ago   #23
Paul Black
Hi davethurston,
[1] I noticed from you specifications that your laptop is a Delium v10IS2, is that correct?
[2] Did it come with a Drivers DVD?
[3] If it was a brand name, I could look for you and get you the latest official sound drivers!
[4] Do you know exactly what sound card is installed?
3 Weeks Ago   #24
davethurston
Hi PB
Answers in order:
1 correct
2 No it didn't which is why I downloaded all available drivers from the ECS website when I got the Netbook.
ECS EliteComputerSystems made Deliums. Audio driver was one of them, for both XP and w7. I've tried both.
3 It wasn't a brand name in terms of dell,hp,acer etc but if you can find later official drivers,yes please.
It was bought from Comet who you might recall folded years ago.
4 No, I am not sure what the sound card is exactly. I assume its onboard audio as opposed to separate board.
The official audio driver downloads I have only identifies it as Reallusion Virtual Audio or Realtek High Def Audio.
Don't forget, those same drivers work fine on the other machine.... headphones switching on/off as normal.
TIA
3 Weeks Ago   #25
Paul Black
Hi davethurston,
Quote   Quote: Originally Posted by davethurston View Post
Three suggestions . . .
First . . .
[1] Click Start => Device Manager.
[2] Expand Sound, video and game controllers.
[3] =>
Right-click High Definition Audio Device =>
Click Update Driver Software =>
Click Search automatically for updated driver software =>
Click Yes, search online this time only.
Second . . .
[3] Right-click High Definition Audio Device => Uninstall => OK.
[4] Restart the computer [
it will automatically reinstall the driver].
Third . . .
Download the Realtek HD Audio Driver from here => Download Realtek HD Audio Drivers.
I hope this helps!
3 Weeks Ago   #26
davethurston
Hi PB
I've tried all three of your suggestions, letting it update driver, letting it reinstall driver and trying realtek v2.82.
No joy with any version.
It's a PITA but I think I'm going to have to reinstall win7 from scratch, just to get headphones working again.
Unless anyone knows of registry fixes...
3 Weeks Ago   #27
Paul Black
Hi davethurston,
If it comes to that, you DON'T need to reinstall [clean install] Win 7, you can perform a Repair Install . . .
A repair install differs from a clean install in the fact that it ONLY replaces the corrupted OS with a new fresh copy. This means that ALL your User Accounts, Folders, Files, Documents, Pictures, Music, Videos, Data Files, Icons, and any installed programs are left intact. It does however, DELETE ALL the WU's [Window updates] installed, and could possibly affect, sounds, services, visual effect settings and device drivers by re-setting them to default [unusual though]. You CANNOT do a repair install at boot, in Safe Mode, using a system repair disk, or using an integrated Windows update disk. Basically, this process can ONLY be performed from within the LIVE OS.
I will have a look into that for you later.
I hope this helps!
3 Weeks Ago   #28
wither 2
Windows 7 Pro SP1 64 bit
Dave-
Yeh, I got looking at the site and there were actually two drivers for Win 7 32 bit for the audio controller. Norton said both were unsafe and deleted each one after I downloaded it. Sorry about that.
3 Weeks Ago   #29
davethurston
wiki article for HDA - Intel High Def Audio has interesting comment :
Intel High Definition Audio
From Wikipedia, the free encyclopedia
Realtek ALC 882 HD Audio Codec
Features of the specification include:[2]
Up to 15 input and 15 output streams
Up to 16 PCM audio channels per stream
Sample resolutions of 832 bits
Sample rates of 6192 kHz
Support for audio codecs (e.g., ADC, DAC), modem codecs, and vendor-defined codecs
Discoverable codec architecture
Fine-grained codec power-control
Audio jack detection, sensing, and retasking
Last comment seems to say this audio driver is responsible (or not) for audio jack detection.
I'll think about repair install....
3 Weeks Ago   #30
Paul Black
Hi davethurston,
Sample resolutions of 8–32 bits
Sample rates of 6–192 kHz
What about this => Realtek HD Audio Codec Driver 2.82 for Windows 7.
I hope this helps!
PCI not recognised...
Hi... A total Newbie here, so go easy please...:-) My aged Win7 machine seems to have thrown the teddy out of the pram... My ATI Radeon Graphics card is refusing to work and I'm now forced to use the onboard Nvidia adapter. I've removed the card and it works fine on my other PC...
Graphic Cards
cant use headphones with computer, pretty sure its not the headphones.
Hello all, I'm having a problem with my turtle beach x12's, and just headphones in general in my computer. i got turtle beach headphones quite a while ago, and i haven't needed to use the mic until now. before i have tried using it, but it has never worked. i dismissed it as a problem with the...
Headphones Not Recognised In Playback Devices, Please Help.
Hey, I'm experiencing frustrating issues with my playback and wondered if you guys could help? Basically I noticed when I turned on my laptop that there was no sound coming out of my Headphones, only the speaker. It was in the right jack as there are only two its not that hard to get right haha....
Dvd+r not recognised
Hi guys I need a little advice with something. I've just been given a box of 500 Dvd+r disks from a company that's closing down, however my bd-rom can't seem to read them. Looking back through all my disks it seems I have always inadvertently always used dvd- or cd-. Whats the difference betwenn...
Hardware & Devices
Two headphones different sound for each headphones?
Hello, In my computer i had plugged in two headphones. One is for my brother, and one is for me. So sometimes we used to hear speeches,music etc... at same time. But sometimes i could feel to play football games. And its sounds will be disturbance for him. So any solution for this?
Twitter Facebook
