Windows 7: Headphones not being recognised on re-connection.
2 Weeks Ago   #1
davethurston
Microsoft Windows 7 Professional 32-bit 7601 Multiprocessor Free Service Pack 1
Hi Win7Forum, Problem using headphone socket.
I have two 'virtually identical' old Chinese Netbooks, both running Win7 Pro - originally XP.
2Gb Memory, 250/512GB HDD.
Both have identical hardware, BIOS and virtually all the same software installed, especially drivers such as audio, chipset etc.
After booting both machines from scratch:
1 Using any pair of headphones on first machine is no problem, repeatedly plugging them in switches off the internal speakers and sound as expected comes out of headphones.
2 Plugging same headphones into second machine works ok until first time they are removed from the headphone socket. After removal, reinserting the headphones into the socket results in silent headphones and sound continues to come out of the internal speakers.
No message is coming up on either machine saying "you have connected / disconnected etc" but the first machine works perfectly whilst the second machine misbehaves.
Volume levels working fine, no yellow flags in either device manager.
Tried removing audio device driver on both machines, and letting win7 install its own default with no change in behaviour.
Installed the Realtek audio driver that seemed to be supplied with original machine, again no change - still silence on second machine. Not sure it should actually be a Realtek driver.... but that same driver works perfectly on first machine?
Obviously the headphones and headphone sockets themslves are working properly but second machine is not recognising the headphones being reconnected.
I can't think where else to look.
Help appreciated.
2 Weeks Ago   #2
wither 2
Windows 7 Pro SP1 64 bit
Don't if I can help but, when you go into Control Panel, Sound, Playback on the problem machine, are the headphones shown?
2 Weeks Ago   #3
davethurston
hi W2,
thanx for ideas, but....
Control panel/sounds/playback -
OK first machine has Speakers (default device) and Line 1 Reallusion Virtual Audio (ready)
No good 2nd machine has just Speakers (default device) only.
Neither machine has any mention of phones, whether plugged in or not.
Tested using same sound files on both mcs, using both vlc player and win media player.
I'll get details of driver files installed and supply tomorrow.
Thanks so far,
2 Weeks Ago   #4
wither 2
I asked you to look because I remember that in early versions of Windows, one had to reset the default device when switching between headphones and external speakers.
Since I was going by memory when I asked you to look for the headphones, I looked further into how to check for them. I found these instructions on another web page this morning-
Open Control Panel and select Sound.
When the Sound dialog appears click the Playback tab.
Verify if the Headphone is listed and the right sound card listed under playback devices.
If so, right click the Headphone device and click on default playback device.
If they are not listed, Right click on the blank space and click on show disabled device.
If the Headphone gets listed,
Right click the “Headphone” select “Enable”. Right click the “Headphone” again and select “Set as default device” from the same list.
Click “Ok”. Now remove and reconnect the Headphone and check.
2 Weeks Ago   #5
davethurston
hi w2,
The only playback devices on either machine in control panel/sounds/playback are default loudspeakers - doesn't mention any sound card devices etc.
no headphones on either machine even when show disabled and disconnected devices are ticked.
Running out of ideas.
thanx anyway
2 Weeks Ago   #6
wither 2
Would you fill out the system specs for the problem system per this procedure-
System Info - See Your System Specs
2 Weeks Ago   #7
Paul Black
Win 7 HP SP1 64-bit Vista HB SP2 32-bit Linux Mint 18.3
Hi davethurston,
Just a thought . . .
Under the heading msinfo32 [MS System Information] - Problem Devices . . ., please run MS_Info32_Find_Problem_Devices.bat, Option [2] from here => BATCH PROGRAMS [Standalone] and then upload the results using the tutorial at the bottom of the above link [Upload to SevenForums . . .] and someone will look at it for you.
I hope this helps!
2 Weeks Ago   #8
davethurston
reply to wither2
updated sys specs as requested.
I haven't used Internet Explorer for a long time, so had to change default from Chrome to IE11.
I got several script errs, don't know why but seemed to work OK see below:
An error has occurred in the script on this page.
Line: 45
Char; 1146
Error: Object doesn't support property or method 'addEvenListener-
Code: 0
URL: https://www.sevenforums.com' profile. php?do=extra
Do you want to continue running scripts on this page?
Yes No
Then similar message : line 6 char 29 Expected Identifier
2 Weeks Ago   #9
Paul Black
Hi davethurston,
Quote   Quote: Originally Posted by davethurston View Post
reply to wither2.
Line: 45
Char; 1146
Code: 0
Yes No
It seems to have pretty much worked except for the Antivirus specification, strange!
2 Weeks Ago   #10
davethurston
Reply to PaulBlack :
Ran batch file as requested:
Hello davet: YOU ARE ABOUT TO RUN MSINF032 - FIND PROBLEM DEVICES?
IMPORTANT: Do NOT close this cmd prompt window while the program is running
Options:
[1] ABORT this process and EXIT.
[21 Run MSINF032 - Find problem devices-
NOTE:
Option [2] creates a Prob_Devices.txt file on the desktop.
>Enter an Option: 2
creating the Prob_Devices.txt file . . .
N0 PROBLEM DEVICES WERE FOUND, deleting the EMPTY file . . .
< Press ANY key to EXIT >
As above, no prob devices were found and the empty output file was automatically deleted from desktop.
Sorry not being much use.....
PCI not recognised...
Hi... A total Newbie here, so go easy please...:-) My aged Win7 machine seems to have thrown the teddy out of the pram... My ATI Radeon Graphics card is refusing to work and I'm now forced to use the onboard Nvidia adapter. I've removed the card and it works fine on my other PC...
Graphic Cards
cant use headphones with computer, pretty sure its not the headphones.
Hello all, I'm having a problem with my turtle beach x12's, and just headphones in general in my computer. i got turtle beach headphones quite a while ago, and i haven't needed to use the mic until now. before i have tried using it, but it has never worked. i dismissed it as a problem with the...
Headphones Not Recognised In Playback Devices, Please Help.
Hey, I'm experiencing frustrating issues with my playback and wondered if you guys could help? Basically I noticed when I turned on my laptop that there was no sound coming out of my Headphones, only the speaker. It was in the right jack as there are only two its not that hard to get right haha....
Dvd+r not recognised
Hi guys I need a little advice with something. I've just been given a box of 500 Dvd+r disks from a company that's closing down, however my bd-rom can't seem to read them. Looking back through all my disks it seems I have always inadvertently always used dvd- or cd-. Whats the difference betwenn...
Hardware & Devices
Two headphones different sound for each headphones?
Hello, In my computer i had plugged in two headphones. One is for my brother, and one is for me. So sometimes we used to hear speeches,music etc... at same time. But sometimes i could feel to play football games. And its sounds will be disturbance for him. So any solution for this?
Twitter Facebook
