Windows 7: Boosting microphone volume
18 Nov 2019   #1
FredTastic
7 Home 64 bit, 7 Pro 64 bit
Win 7 home 64 bit. I use Google Voice through Chrome to make long phone calls. I would like to boost the volume of the microphone I use when making calls. I have looked through all the sound settings, properties for the default mic (the one I'm using) and everything is set as loud as it can be. I have this issue with the onboard sound card, as well as with a PCI card I added. Exact same volume level. It is recording, but at about half the volume I would like. Again everything in sound/recording/default device/properties is as high as it can be. The card has no "boost" in that dialogue, while the onboard did, but setting it at 100% makes no difference. Anyone know of any utility or similar I can add to boost mic volume? The issues isn't just there when on Chrome/phone calls, if I go to "Record" the volume is the same low level.
TIA
19 Nov 2019   #2
samuria
win 8 32 bit
It's either the wrong ohms on the microphone or you will need a preamp
19 Nov 2019   #3
Snick
Agree!
19 Nov 2019   #4
FredTastic
I'm getting decent improvement using this EQ Equalizer APO download | SourceForge.net
Microphone Volume is quiet, even at maximum volume
So I recently moved my microphone/headset plugs to the rear jacks of my computer, the reason I did this was because when plugged in to the front jacks, my microphone had a white noise I couldn't get rid of, the rear jacks doesn't have this issue, but my mic volume is quiet I think it might be a...
Microphone volume too low
Just installed the release candidate of Windows 7. Was previously running Vista. I use Skype a lot, and my microphone volume level is much lower now than it ever was. People are telling me they can hardly hear me when I call them. I have a Dell Inspiron 1525 laptop- the mic is built-in. I've...
Microphone volume is agonizingly low
Every textbook way to fix the mic being low has failed for me. Can anyone help? It needs to be pretty much be in my mouth to be a decent volume. Microphone levels at max + boost? Tried it. Set the correct microphone port as default device? Tried it. Double check communications tab to...
Microphone volume reduced
Hello All, I did a fresh Windows 7 installation on a new hard disk drive on my laptop.I am using Dell Inspiron 1525 laptop.However, after installation the microphone seems to be behaving weirdly(volume has reduced).I see that the system is automatically adjusting the volume of the...
Microphone volume won't stay put
I want to lower my microphone volume from 100 to 50. When I do it, it will stick around for a little while (while I record something), but then it will jump back to 100 sometime after I'm done or even before I start. For some reason, the adjustment just won't be saved. I'm hitting OK to close the...
Twitter Facebook
