Windows 7: ZEXMTE Bluetooth USB Adapter volume problems.
06 Jan 2020   #1
Androshi
Windows 7 Home Premium 64-Bit
Hey guys,
To keep it short, I've been using the ZEXMTE Bluetooth USB Adapter CSR 4.0 USB Dongle Bluetooth Receiver to connect my Powerbeats pro to my win 7 desktop. Just yesterday, all of a sudden I cannot control the volume through my earhooks anymore and I have no idea why I did not change anything at all so after hours of searching online to no avail I ask here what the problem is. I have tried uninstalling the drivers and re-installing them through the given disc with the adapter but it didn't fix a thing. The only thing I have control over is pausing and playing while using itunes. I know that I can just adjust the volume with the slider on itunes or going to the property settings, however I want to use the powerbeats volume control buttons themselves. So how should I go about this? Thanks.
06 Jan 2020   #2
oscer1
hi it could be that the headphone buttons are just faulty. how old are the headphones?
06 Jan 2020   #3
Androshi
Quote   Quote: Originally Posted by oscer1 View Post
These powerbeats pro are 3 months old and they can't be faulty seeing as I have tested them with my iphone and there were no issues with the volume controls while listening to songs on itunes. However, when connecting them through the bluetooth adapter the controls are suddenly not responding with itunes or any other media player for that matter besides play/pause. So, at this point I have no clue as to why this is occuring.
How do I fix my bluetooth adapter?
I reformatted my laptop, an Asus k43sj, 2 days ago. And I am looking for drivers over the net. But I can't find a bluetooth module(according to Driver Toolkit which I downloaded to find what drivers I lack). I uninstalled it on Device Manager and reinstalled it and actually hoped it will work but...
Drivers
My bluetooth adapter won't connect to my bluetooth headset
Hi !! I am having a bluetooth adapter installed on my PC. Now I wanted to connect my Samsung HM1100 headset with it. It paired and everything but during installation of driver it says "NO DRIVER FOUND". I have tried too many times and I have also installed a bluetooth driver "SILICON WAVE...
Drivers
USB Bluetooth Adapter's Blue Light IS LIT When Bluetooth Is OFF?
Hello. I have an issue with my Medialink USB Bluetooth Adapter - Version 4.0 Class 2 Smart Ready Adapter (Model No. MUA-BA3). Let me explain... Okay, I have setup my Medialink USB Bluetooth Adapter with the drivers for my Windows 7 operating system. Now, when I plug this USB Bluetooth...
Hardware & Devices
bluetooth adapter?
i went to a computer store, and they told me that my netbook needs an adapter in order to transfer data wirelessly from Android. Is there another way to do this?
Hardware & Devices
Bluetooth USB Adapter ES-388 V2.0
Hey, I got a Bluetooth USB adapter (model number is ES-388, no brand) so that I could use my Bluetooth A2DP headset with my Windows 7 PC, but I can't seem to get it to work. Windows does not recognize the device (the adapter), and won't activate it. Is there a driver that I need to install? ...
Drivers
Twitter Facebook
