Windows 7: BT headphones connect to pc but no audio
1 Week Ago   #1
kruuth
Windows 7 Ultimate 64 bit
I've tried two different BT adapters. The headphones get detected but I can't get any sound through them.
Configuration:
Windows 7 Ult 64-bit Service Pack 1
32GB RAM
MOBO ASRock 970 Extreme 3
I've tried two BT adapters. The one there now is manufactured by Cambridge Silicon Radio. The other just shows up as GenericAdapter. the first time I plugged in the Cambridge one, I went to do the music and it did sit there for a minute, but then went right back to acting like there was nothing there. Under audio devices, there is a Bluetooth Headset and Bluetooth Headphones, but both always read as disconnected. Whenever I install the devices, I check all of the options when I install it. Is there something that I am missing in order to get this to work?
1 Week Ago   #2
iko22
Windows 7 x64, Vista x64, 8.1 smartphone
Hello kruuth,
Last time I saw BT headsets with no sound was when the bluetooth adaptor had a different BT version to the headset. The BT adaptor needs a version of at least the same or higher, as the headset. Does that help?
1 Week Ago   #3
kruuth
Makes sense, I can take a crack at it. Shouldn't be an issue.
1 Week Ago   #4
kruuth
Ok, just plugged a new BT 4.0 driver in. According to Aftershokz, I need BT 3.1 or higher. They still do not show up in the sound options, just the two BT headsets but both of those are greyed out.
1 Week Ago   #5
kruuth
I tried setup forwarding VoIP calls. That failed.
1 Week Ago   #6
iko22
Quote   Quote: Originally Posted by kruuth View Post
Had you re-paired the devices by Right-click the BT icon (in the systems tray) and choose “Add a Bluetooth Device” from the context menu.
1 Week Ago   #7
kruuth
I just tried re-pairing the device. It connects, but when I go to the operations option and choose "Listen to Music" it doesn't do anything. Forwarding VOIP calls fails.
1 Week Ago   #8
kruuth
Any ideas?
6 Days Ago   #9
iko22
In Window's Sound settings, Playback tab, does your device show up?
If so, click it, and then choose Set Default.
This will set the Bluetooth device as the default audio device.
3 Days Ago   #10
kruuth
It's not even showing up.
CSR Bluetooth 4.0 - how to make it connect headphones?
Hi, I've searched here and not found this specific answer, so I guess I need to post the question. I've just bought CSR bluetooth adapter (TP-Link) for a Windows 7 laptop because Broadcom Bluetooth is problematic on Win7. The CSR Harmony software installs fine, the adapter is recognized, the...
Hardware & Devices
Is there a way to auto connect Bluetooth headphones?
Greetings! I just recently bought a pair of Bluetooth headphones to use with my laptop. Every time I want to use them, which is daily, I have to start up my list of Bluetooth devices and select the headphones and then when the connect window pops up, my headphones are automatically connected as...
Hardware & Devices
Blutooth headphones won't connect
Have got myself some Bluedio Blu tooth headphones to save the cables etc however all attempts at getting these phones to connect is proving to be really annoying, and I have followed the manufacturers instructions to the letter. Thing is it shows in added in Devices and Printers and the Blu...
Hardware & Devices
How to connect wireless headphones to PC
Had no success googling this, so maybe help here? Have a set of wireless headphones. Works fine with my ipod & mobiles. But how to pair up with win7PC? Have a dongle bluetooth. It can see the mobiles in the house but not these w/less headphones. I've held the button down to initiate fast...
Run scheduled task when I connect headphones
Hi, I'm trying to use the win7 Task scheduler to automatically open an app when I connect headphones, but I can't figure out the event ID/log for connected jack. When I connect/disconnect a jack, I get a taskbar notification, and C:\Windows\System32\config\SYSTEM gets updated.
Customization
Twitter Facebook
