Windows 7: Sound Blaster Command *and* Sound Blaster Connect?
24 Feb 2020   #11
NoN
I will read about your card aswell along mine. Not so many external tips are proposal for those kind of cards, there is one here that helps to switch
Quote:
SBZ Switcher - Automate Speakers/Headphones mode switching
this tool allows automated switching of Speakers/Headphones and more for Creative Sound Blaster Z-Series and Recon3D owners.
while the master volume and mute controls are handled in the OS level, the switching mechanism is on-screen
auto click based, thus is dependent on Sound Blaster Control Panel availability.
SBZ Switcher is synchronized with the Sound Blaster Control Panel via registry, to display current info and switch accordingly.
, call SBZ Switcher: SBZ Switcher - Double click Speakers/Headphones mode switching available | guru3D Forums
dunno if it's works for AE-5 series as the project stopped.
Edit: Seems Pax drivers for my card being dropped since April 10th, 2017..
24 Feb 2020   #12
msalton1
windows 7 Pro 64 Bit
Quote   Quote: Originally Posted by NoN View Post
I will read about your card aswell along mine. Not so many external tips are proposal for those kind of cards, there is one here that helps to switch , call SBZ Switcher: SBZ Switcher - Double click Speakers/Headphones mode switching available | guru3D Forums
I don't currently use headphones, although that would change were I to get into gaming again.
The 'external sound solutions' I mentioned are stand-alone. They are purported to be much higher quality than internal components are able to produce. The pricing is a bit more, but alleged to be worth the extra money. I'll give those a shot for the next machine I build (planned for the near future). I believe that the external solutions wont' work with analog speakers.
I did run back to pax and check...seems there is no support for the AE-5. If there were, I would likely try older PAX drivers anyway, since they may well surpass Creative's in quality and stability. For anyone trying this, I would recommend creating a system image before installing (Macrium Reflect Free is a good choice).
That said, I decided to try running SB Command again (I've been using SB Connect) and am thinking that they actually do sound better than the SB Connect. The SB Command employs the newest drivers.
Creative Sound Blaster Audigy FX Sound Card, no playback/recording
Hi, I recently purchased the Creative Sound Blaster Audigy FX and am having problems getting it to actually play any audio or record any sound. I've browsed other threads with similar issues on this board and as such have disabled my motherboards onboard audio in my BIOS settings, have...
Sound Blaster Audigy 2 Platinum ex does not sound in Win7x64
Hello; I'm trying to make my "Sound Blaster Audigy 2 Platinum ex" works on Windows 7 64 bits, I did install the most new version of the drivers provided by Creative Labs, it seems like it is installed without any problems....the Device Manager shows all drivers are installed correctly...when I...
Sound Blaster X-Fi Titanium Sound card issue
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update...
Garbled sound NF4/Sound Blaster XFi Gamer with over 4GB memory
This seems to be a problem that Creative has not been able to fix with new drivers. The work around is to limit the computer to below 4GB of memory. Has anyone come up with drivers that work so I can use all my memory?
Drivers
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Twitter Facebook
