Sound Blaster Command *and* Sound Blaster Connect?
  1. Posts : 325
    windows 7 Pro 64 Bit
    I recently installed an AE-5 in a newly built machine. Creative installs both 'command' and 'connect'. SB Command seems like an older version and does not provide options for 5.1 surround (SB Connect does).
    Does anyone know why (or if) both are required?
  2. Posts : 2,246
    Windows 7 Pro SP1 64 bit
    It took me forever to find SB Command. The first instance I found is an app for a android device. When the app is loaded onto the android device and the latter is connected to your computer where the speakers are installed, it's supposed to be able to configure your speakers. I installed it on my LG Android device which is connected to this system via USB. This system has a Sound Blaster Audigy sound card. When I click on speakers, it asks to connect to an audio Device. However, it never finds any devices. I have a set of 5.1 Logitech speakers connected to this system. Maybe I'm misunderstanding and the speakers need to be connected to the android device.
    Being suspicious, I did a little more looking and found the SB Command for Windows. When I tried to install it, it was taking forever to install. I'm going to try to install it again tomorrow when I have more time.
  3. Posts : 26,869
    Windows 11 Pro
    @msalton1 do you have the Sound Blaster control panel installed? It may help you.
  4. Posts : 2,246
    I finally got SB Command installed but it won't run, probably because I don't have the A-E speakers. Windows just says it stopped working and Windows is checking for a solution. We all know how that goes.
  5. Posts : 325
    No, only what was provided at the Creative download page for the AE-5 (SBcomm & SBconn). The documentation doesn't mention the SB control panel, is it compatible with the AE-5?
    I'm guessing the SB command download was to accommodate 2 speaker systems. SB Connect has the "BlasterX Acoustic Engine", which is obviously made for the card, but it's not very well developed, IMO. Here's a screen cap:
  6. Posts : 325
    Are you installing for the sake of this thread or having a problem of your own? Neither of these softwares are well designed. Creative's AE-5 support page doesn't provide an android app other than one called "Scout" for gaming, but I wouldn't need it anyway.
  7. Posts : 2,246
    I was downloading the android and windows versions in an attempt to see if the speaker function would detect different arrangements such as 5.1 that you desire.
    The Android version is here-
    Sound Blaster Command - Apps on Google Play
    Didn't notice until today that it says it works with Sound Blaster X3 and G3. No mention of A-E. I didn't install the Super
    X-Fi.
    I went to this Creative website this morning. The website shows that I have to log in to my account to enable the app. Didn't know that because it went directly to the dashboard after installation.
    Creative Worldwide Support > Knowledgebase Solutions
    I put in my SoundBlaster e-mail address and password and it kept saying one of the two was incorrect. I tried to reset it and it said my e-mail address doesn't exist. Wrong!
    So I go to the troubleshooting guide for the SB X-3-
    and in the "no sound" section, it says-
    Choose the correct speaker configuration type in the Sound Blaster Command application. (eg. Stereo /5.1 / 7.1)
    so, apparently, the Command is supposed to let you choose.
    However, I just found out that the SB X3 is an external device so, I don't know why the Command software would be installed with your sound card.
    Sorry about the rambling.
  8. Posts : 325
    I emailed Creative tech support. They say either or (as far as SB Connect2 or SB Command go). The SB2 struck me as the better audio performer.
    @essenbe They also say that SB Control Panel isn't compatible with this card.
    When I get a chance, I'll look into the pax drivers (if available) and see if they offer better performance/stability. I hope so. The software/drivers are really pretty pitiful.
    Questions asked:
    Basic Questions for AE5:
    1. The download page for the AE5 contains only two files: SB Connect & SB command. I ve installed both, but they seem redundant. Are both necessary (or beneficial) to have installed for the AE5?
    2. Is Sound Blaster Control Panel recommended for this card?
    Thanks!
    Creative's response:
    Thank you for contacting Creative Labs.
    To answer your questions:
    1. It is not necessary. However, please note that the newest driver is bundled with the Sound Blaster Command app.
    In addition, the only feature that you need to take note for the Sound Blaster Connect is for you to adjust the LED lighting for the sound card.
    2. No, we only recommend either the Sound Blaster Connect or Sound Blaster Command applications for this specific card.
    Also, the sound blaster control panel is incompatible with the AE-5.
  9. NoN
    I feel a bit at shame since we discuss about Creative Sound Cards here:New Sound Card for old Logitech Z5500 speakers , that you're not totally happy with.. Mine Sound Blaster Z have slightly the same UI control Panel as essenbe.
    I enjoy that card a lot and found it easy to use the parameters with a 5.1 sound system.
    You should have those options somewhere and have to dig deeply the parameters.
    Attached Thumbnails Attached Thumbnails Sound Blaster Command *and* Sound Blaster Connect?-capture.jpg   Sound Blaster Command *and* Sound Blaster Connect?-capture2.jpg
  10. Posts : 325
    No need to feel bad, NoN. I am happy with the card and appreciated your input. Thanks for your comments here also. The software/drivers aren't what one would hope, but there are possibly PAX drivers to explore, I just haven't had time to do so. The card itself is fantastic and is capable of very high quality output. The quality is so good that it exposes flaws in the older mp3s in my collection that were ripped at a lower bit rate (HDD storage space was at a high premium in those days. I started rips at 128 kbps...I now rip at 320 kbps with lame encoder inside MediaMonkey).
    If you are interested in reading about the PAX drivers, here is a site that may interest you. The discussion for your 'Z' is about 8 down:
    PAX Drivers | Hardware Heaven Forums
    They also talk alot about external sound solutions. Schitt Audio seems to be highly regarded. I really don't want any more stuff on my desk, which is why I went with PCIE, but may try the external solution later.
    Thanks again for your help.
