Windows 7: CSR Harmony bluetooth 4 pairs but will not connect
22 Feb 2020   #1
realflow100
Windows 7 Pro x64
Nothing appears in services. I cant get bluetooth to work!!!
22 Feb 2020   #2
Barman58
Windows 10 Pro x64 1909 - 18363.657 XP/Vista/Win7/Win8.1 in VM for testing
Checking the specs of the system at HP It does not mention bluetooth support, are you using a USB dongle and if so do you have the correct drivers installed and running correctly (the services screen you show would suggest that the bluetooth subsystem is not running),
If you have everything installed and running correctly the system or Dongle, Bluetooth version will need to be the same or later than that of the device
The HP page I checked is Here ... HP Compaq Elite 8300 PC Product Specifications | HP(R) Customer Support
22 Feb 2020   #3
realflow100
Windows 7 Pro x64
I'm using a USB bluetooth adapter thingy. but idk where to get drivers for it
its bluetooth 4.0 costech brand
I dont have a cddrive and dont have orginal drivers for it
please help
I have windows default driver installed (it automatically installed it by windows update)
but its not working. even after repair-installing windows with a repair cd and "upgrading" windows over top of itself!
i cant get it to work
Devices will pair but dont make any sound or show any signs of actually being connected and so no drivers get downloaded for the device.
sometimes in windows hardware and devices page it will show it alternate every couple seconds between connected and disconnected
but nothing happens on the device itself.
i'm trying to connect a bluetooth speaker
23 Feb 2020   #4
Barman58
Had a look around for details on Costech and they appear to be one of those companies that sell everything you can think of - from bed sheets to computer hardware. they do list a CSR v4.0 bluetooth adaptor and there are a few links on the net to this device and users looking for working drivers, without any success. apparently they are supposed to work out of the box with the windows drivers, however there are a lot of users who appear to have similar issues to yours.
I cannot find an actual location for the company, they show up on search down the list after a dental Lab! could be anywhere worldwide, you may have more luck going through your local US sales source, there is supposed to be a disk with the item with drivers which you could possible obtain and use a system with a CD/DVD player to extract them for use .
Bluetooth adaptors have long been an issue with reliability, partly due to the fast rate of development, but also as there are a lot of companies that produce sub standard items cheaply - I personally only use items from Major brands but have been lucky with cheaper units in the past
23 Feb 2020   #5
realflow100
Windows 7 Pro x64
I found CSR Harmony bluetooth 4.0 driver and it WORKS FINALLY!
its different than windows built in bluetooth driver. and actually works
i can finally connect my bluetooth speakers! and sound works!
I can supply link if you think that would be a good idea
24 Feb 2020   #6
realflow100
Windows 7 Pro x64
https://archive.org/download/CSR4.0H...%20drivers.zip
WORKING drivers for bluetooth USB sticks/adapters on windows 7
These are the ones that finally worked for me!
here they are for anyone else to download
The author will have to mark it as solved themselves. or staff/admin/moderator
Bluetooth headset pairs but won't connect, not avail as playback devic
My setup: Windows 7 64bit Prof (on a suped up PC) Asus BT211 - BT 2.1 + EDR (full A2DP support with latest Win7 64bit drivers - Broadcom Bluetooth 2.1 +EDR driver version 6.3.5.430 (4/8/10) Sony DR-BT101 Headphones - (Microsoft says they're compatible) PROBLEM: All BT devices successfully...
Speaker pairs with Bluetooth but no sound from speaker
Thanks in advance for any help. I paired a UE 2 Boom speaker to an 2010 ASUS 1005 PC net book. The speaker is paired, but streamed music is played by the netbook speakers, not the UE Boom Bluetooth speaker. I have tried to update the Bluetooth drivers for the netbook, but it says I have the...
My bluetooth adapter won't connect to my bluetooth headset
Hi !! I am having a bluetooth adapter installed on my PC. Now I wanted to connect my Samsung HM1100 headset with it. It paired and everything but during installation of driver it says "NO DRIVER FOUND". I have tried too many times and I have also installed a bluetooth driver "SILICON WAVE...
Drivers
I can not connect Bluetooth devices.
I have a Medialink Bluetooth dongle that I am unable to get to work with all my bluetooth devices. I have the drivers installed and everything seems as if it should be functioning properly. However, I am not able to pair my two Android devices or my Turtle Beach PX5 headset. I was able to...
Hardware & Devices
Can you connect to the internet with bluetooth?
Hello I am new to the bluetooth technologies and I have the following question. Can you connect to a wifi network through a bluetooth usb adapter?
Network & Sharing
Twitter Facebook
