Windows 7: My audio makes horrible periodic noise
16 Mar 2020   #1
nijjhar
Windows 7 Home Premium 32bit
Hi Brethren,
I am using W7 Ultimate and recently I changed my monitor to hpw2007v and my audio has started making noise after some time.
I got the notice about Audio renderering and asked me to restart my PC, which I did but to no effect.
I have tried what Youtube people have suggested:-
Device Manager, sound, Realtek disabled, yes and then enabled. Restarted my PC but no good.
Any suggestions?
Also, I did upgraded my PC to W10 when it started but my PC was crashing. After suffering a lot, I went back to W& Ultimate.
Now, I want to go back to W10. Please suggest whether my old PC will take it or not.
Here is screen shot:-
It will not paste. It is Acer 2009 or so SIND No. 92400118330 32bit
I am not a technical man.
I Preach Christianity and so far, I have put over 7300 Youtube Videos; channel nijjhar1. In case, someone has interest as True Gospel is not known to the University Professors plying dead letters.
17 Mar 2020   #2
wither 2
Windows 7 Pro SP1 64 bit
You've already posted regarding whether or not your pc is suitable for Win 10 in another thread. Someone has replied to that. If you want to get help fixing your current problem, then say so.
17 Mar 2020   #3
Snick
Opened case and vacuumed it out, now fan is making horrible noise!
Computer: Gateway DX4831 Windows 7 Home Premium Last night I had to move my desktop computer so I decided to open it up and vacuum out all of the dust in the six year old box. It was pretty bad in there and I had a vacuum cleaner going while I hit the computer with compressed air and I thought...
Hardware & Devices
Fan makes a lot of noise
I've been noticing that my laptop fan has been making a lot of noise at times, mostly while playing games on Facebook or watching videos on Youtube. Last year my laptop had been heating up and shutting itself off and I opened it, cleaned it and applied thermal paste. I've done the same now...
Performance & Maintenance
DVD makes noise...
Hi, There is something wrong with my DVD-drive whenever I put a data CD it spins very fast and makes too much of noise while reading the data... LG HL-DT-ST DVDRAM GSA-H42N ATA Device Regards Hari Om
Hardware & Devices
Monitor makes a noise
My computer monitor, HP LP3065c it's 30", makes a very very faint noise when it comes on. Is this normal? If not what can be done? I've had it since it was first released on the market several years ago and I'm wondering if it may be getting tired. Thanks for your help.
General Discussion
When starting win 7 the speaker makes noise until audio driver is used
Hello. I have a computer with external active speakers connected to the 3.5mm phone plug. I'm using win 7 32-bit and when I start my computer the speaker starts to make strange sounds, almost sounds like an old modem. I have disabled the start-up sound since I don't want that, the noise is there...
Twitter Facebook
