Windows 7: External CD-->HTPC-->TV using Foobar2000 no audio at stand-by
3 Weeks Ago   #1
StrugglinTech
Windows 7 HP_64bit
So recently I added a laptop dvd drive to my HTPC using a USB adapter. I wanted to play music through my theater surround sound which is actually just a Klipsch powergate (so not allot of extra inputs on it). This requires my TV to be on and has audio coming over HDMI. Once I looked into this, there seems to be quite an issue using this method having it cut audio after it goes into stand-by.
My issue is that I have an older Samsung flat screen 40". So if I leave the picture the same for more than say, 20 minutes it begins to burn the image into the screen. To fix this problem I instituted the old screen saver functionality of Windows 7. The idea was that I could bring up a disc(CD) in Foobar2000 and then after a short time the screen would run the screen saver to keep my LCD from burning-in with the menu of Foobar's playlist. Things were working fine then 1 minute or so after the screen saver came up the audio stopped playing. The DVD drive completely shuts off. So I dug around USB powersaver areas and made sure to uncheck all the boxes having to do with saving power and it still happened. Then I dug in preferences in Foobar2000. In the playback area there's a box you can check that says " Prevent screensaver & monitor standby when playing (needed for: audio over HDMI, Windows tablets with connected stand-by)"
Which sounds like it will solve my playback issue, but that's not going to help my TV LCD any from getting burned in. Why can't I have the monitor sleep while everything else is working?
3 Weeks Ago   #2
Wandering one
Win7 sp1 Pro 64bit / XP sp2 Pro (games only)
Try setting up a repeating slideshow with a dozen or more pictures. Computer should be happy and stay awake.
Art.
Lost HD Audio on Assassin HTPC! Was it the recent Windows Update?
Lost HD Audio on Assassin HTPC! Was it the recent Windows Update? All of the sudden I have lost my HD audio output on my Assassin HTPC with ASUS Graphics Card and AMD chipset. I can see audio on the level meter but nothing comes from the speakers. I know if is not the TV or the Onkyo Tuner. Once...
HTPC doesn't see my external USB3 HDD
Finished my HTPC build today and plugged my external HDD in and it doesn't show in My Computer. I clicked on "show hidden" and it just shows my card reader. Specs: MB: MSI H87M-G43 CPU: Intel i3 Memory: 8GB Corsair Dominator PSU: Corsair RM550
Hardware & Devices
Playing Audio on HTPC - How to Keep Windows From Idling?
I have an HTPC that's hooked up to my A/V receiver and surround sound system. Because of this, I also like using it to play audio files. What I can't figure out, however, is how to keep Windows from idling, and my A/V receiver from dropping the HTPC input due to inactivity while playing audio...
Music, Pictures & Video
How to make external hard disk sleep/stand by in Windows 7
Hi, I'm using Dell studio 1558 laptop with Windows 7 and 8 in dual boot. I've 2 external hdd, WD my passport 0740 and Sony HD E1. well in windows7, these 2 ex-hdd or any one of them doesnt go to stand by, but in windows8, they go to stand by (stops spinning, indicator led goes off). In...
General Discussion
Transfer Rate lagging on USB 3.0 from WHS to external drive on HTPC
I am copying files from a WHS 2003 to a back-up drive on a HTPC. The WHS and the HTPC are connected physically to a router. The back-up drive is USB 3.0 and plugged into a 3.0 USB input on the HTPC. The transfer rate is only 40MB/second. Why is this? The data is being transferred via CAT6...
Hardware & Devices
Twitter Facebook
