Help!!!!! Sound card
  1. Posts : 1
    Windows 7 ultimate x64
    How Can I get sound drivers for Dell optiplex gx520
  2. Posts : 2,774
    Windows 7 Professional 64-bit
    In older days of ancient past, one could put the Service Tag number into a designated Dell web page and that would lead to unit specs, drivers, help stuff. sevenforum folks: Did that change over the years?
  3. Posts : 0
    All of your drivers are here: https://www.dell.com/support/home/en...-gx520/drivers
    However, the computer only supports XP. You might be able to use the XP driver in Windows 7, but it may fail on installation. Your best course of action would be to buy a USB sound card which isn't much at all.
  4. Posts : 2,774
    usb SoundBlaster maybe?
  5. Posts : 733
    Windows 7 Pro 64-bit / Windows 10 Pro 64-bit (dual boot)
    Your Dell OptiPlex GX520 has an Analog Devices ADI 198x Integrated Audio (SoundMAX) audio device.
    There are Windows 7 SP1 drivers for it at the support site for the Dell OptiPlex 780.
    https://www.dell.com/support/home/en...e=optiplex-780 (32-bit)
    https://www.dell.com/support/home/en...e=optiplex-780 (64-bit)
    It should work fine in your Dell OptiPlex GX520.
  6. Posts : 0
    Now you'd think Dell would at least do us a solid and make mention of that ability on their download page.
