All Audio Services have disappeared, No audio devices visible at all?
Page 2 of 2 FirstFirst 12
  1. Posts : 7,225
    if SIW2 instructions fail,
    1) DID you update the Asmedia root hub driver problem
    2) run sfc /scannow
    3) run KB947821
  2. Posts : 7
       #12
    SIW2 said:
    you can try.
    copy and paste what is in the code tags using notepad and save it as a .reg file call it anything you like, for example
    audioendpoint.reg
    then double click on it to merge it into your registry. Or rt click it and select merge
    I will give that a try. Thanks for the assistance.
    DAA
    - - - Updated - - -
    Even though I have changed the file's name, I can not seem to get my Notepad file to become a.reg file.
    The option to view as such is not available.
    I appreciate your help.
    DAA
  3. Posts : 7,225
    Re the Asmedia root hub problem, yellow exclamation mark in the device manager screenshot first postw
    you did not appear to answer the questions i raised.... so whats the point in helping you
  4. Posts : 7
       #14
    On the contrary, I am very thankful and plus I have not been to the forums as often as I ought to have, and I also failed to notice that in your previous post. Apologies.
    Daa
    - - - Updated - - -
    All Audio Services have disappeared, No audio devices visible at all?-image.png
    What though is ASmedia? Could you highlight that for me.
    Thank you.
    Daa
    - - - Updated - - -
    Installing it now...
    Daa
    - - - Updated - - -
    Now installed, but still getting the no Audio Services, etc...
    - - - Updated - - -
    2) run sfc /scannow < Now, I have to run this. Got that.
    3) run KB947821 < how do I engage this though?
    Appreciate all your help.
    Daa
    - - - Updated - - -
    Scan on the way...
    Daa
    - - - Updated - - -
    Scan complete... No #errors found.
    - - - Updated - - -
    Now found at Microsoft and installed...
    - - - Updated - - -
    All three of your suggestions have been implemented. No audio devices have shown up yet.
  5. Posts : 16,540
    7 X64
       #15
    DAA
    - - - Updated - - -
    DAA
    the letters after . are file extensions
    Have you got file extensions showing ?
    File Extensions - Hide or Show
      My Computers
  6. Posts : 7
       #16
    Not until I click on them.
    - - - Updated - - -
    I got the.reg to work and merged the settings to my registry thanks to your how-to link, but haven't got audio devices as yet?
    - - - Updated - - -
    Hey! Guess what... all your help has paid off. Merging the .reg file has done the trick.
    I want to express my gratitude to SIW2 and Torchwood for their assistance in resolving this annoying pesky audio problem.
    To the both of you, your help was much appreciated. For that, I am really grateful. Yes, indeed.
    Thank you, SIW2 and Torchwood.
    All Audio Services are back online and showing. 👍
  7. Posts : 16,540
    7 X64
       #17
      My Computers
