Windows 7: Surround System Problem
01 Dec 2009   #1
aliawaiskhan
Windows 7 64-Bit
Hey everyone,
I installed windows 7 today, I'm a big fan of hooking up my comp to the TV and watching movies. It was a pain to get the video card working but all is good now. When i thought I was ready to start watching some quality TV, I came across an even bigger problem: Only 2 of my speakers were working, i went to the hardware and sound configs in the control panel and set it to 7.1 surround, sure enough it recognizes all of them, when i test it all 7 speakers and the subwoffer work perfectly, however no other program is using them, they all only use 2 speakers .
I've tried winamp, vlc, windows media center, media player classic and it happens with all of them.
Help!
01 Dec 2009   #2
zigzag3143
Win 8 Release candidate 8400
Quote   Quote: Originally Posted by aliawaiskhan View Post
Hey everyone,
Help!
Hi and welcome
It is still probably a driver issue. can you check device manager to see if your driver is installed, and working properly.
type device manager in search>sound tab>Is your device listed? is there a yellow triangle on it? are there any other "unknown" devices?
Kenn J+
01 Dec 2009   #3
aliawaiskhan
Windows 7 64-Bit
Please see...
There is no yellow triangle on it....
03 Dec 2009   #4
aliawaiskhan
Windows 7 64-Bit
Still no reply.......
04 Dec 2009   #5
Orlander
Windows 7 /64
I have the same sound card as you but when I checked it in Device Manager, mine names the device as "Creative SB X-FI" and that's it. Yours has "Vista" added at the end.
Are you sure you have the newest drivers installed?
After installing Windows 7 / 64 a few weeks ago, I went to the Creative site and downloaded and installed the latest version on the driver and software packages for the card. I've had no sound related problems since.
Good luck... you have good taste in sound cards, by the way!
05 Dec 2009   #6
aliawaiskhan
Windows 7 64-Bit
Orlander Thanks for reply.
I go to updates and update my sound card too now i am enjoying my 7.1
i have also corei7 and a heavy duty GTX 295 Gaming Card
05 Dec 2009   #7
Uber Philf
W7 RTM Ultimate x64
Hey everyone,
Help!
If i'm not mistaken, don't you have to set the sound options in each program to 7.1 to make it effective?
06 Dec 2009   #8
aliawaiskhan
Windows 7 64-Bit
I checkd and verify there is no need to set the sound option in each programe
08 Dec 2009   #9
Orlander
Windows 7 /64
You are welcome.
I have to hand it to Microsoft. Windows 7 is so much better then XP.
Nice setup you have there. I have the EVGA GTX 275 with a Q9550 quad. No i-Core in my near future... need a job first
Bluray Home theater system used for 5.1 surround gaming?
I just bought a creative sound blaster usb sound card that supports dolby digital live and can convert any audio into 5.1; I'm planning on optical out. I have not purchased a theater system yet, because I have a question. 1. Is it possible to use a bluray home theater system to play Pc games in...
cyber acoustics surround system 5150 5.1
can some one help me out i heve a cyber acoustics surround sound system 5150 5.1 and i only get sound out ov 2 speakers i heve dunn a test on all speakers and all ov them graft.properly..?????:p my computer is an acer aspire x-1300.
Suggestions for buying 5.1 Surround Sound System!!!
Hi all :) I'm planning to buy 5.1 Sound System for my PC. I'll be using it for Gaming and listening to Music and my budget is about 90 to 100 bucks (of course converted in my currency) The speaker systems i liked are Logitech Z506, Logitech X530 and Creative T6160. Now i wanna know which one should...
5.1 Surround issue, brand spanking new system
Hello everybody, I'm posting this evening in hopes I can get some help with a problem I've been having with my surround sound speakers. I have a set of Altec Lansing speakers, which have worked flawlessly in the past (on a Windows 7 system I might add). I recently purchased a new computer...
New surround system. Center Channel issue
So I picked up a new Logitech X-540 5.1 channel surround sound system the other day. This is my first 5.1 channel system for a pc so I'm not sure what all needs to be done to get it running correctly. I hooked it all up and went in to Sound then clicked configure on the default speaker device. I...
