Onboard Realtek Audio ALC883 is not detected
  1. Posts : 3
    Windows 7 Professional x64
    I installed Windows 7 Pro x64 and did all the updates but no sound. I have tried installing the latest drivers for the 64bit for the Realtek ALC883 but it still did not work. I did not think it would since Windows 7 is not detecting the onboard audio device. I have tried disabling the audio hardware in the bios and booting to windows then doing restart and re-enabling the onboard sound in bios and booting to windows. It is still not being detected by Windows 7 Pro x64. Any ideas?
    Thanks for any help you can provide
    Insleyg
    MB - Asus M2A-VM
  2. Posts : 1,039
    Windows 7 Ultimate x64 Service Pack 1 (Build 6.1.7601)
    Try reset your Bios to Default settings.
  3. Posts : 3
    I tried your suggestion, unfortunately no audio device is seen as installed. I tried loading the x64 vista version of the drivers in compatablity mode, after doing what you suggested, and they installed fine with no errors but I still no sound.
    Any other suggestions would be helpful. My Award Bios version 0804.
    Insleyg
  4. Posts : 1,039
    Update your bios: ASUSTeK Computer Inc.
  5. Posts : 3
    Updated the bios. The sound works now!. Also, the update cleared up a problem I was having with video display.
