Audio problem
  1. Posts : 5
    windows 7
    Audio problem
    I can hear both of my speakers sound from one speaker itself while testing, I tried all the options nothing working plz can anyone help...
  2. Posts : 3,141
    Hello Vinay. Welcome to 7 Forums.
    What options have you tried? Is one of the jacks working and one not? If you go to User CP, you can fill in your system specs. That may help.
    Gary
  3. Posts : 5
    windows 7
    HI Gary, thanks for reply
    actually I tried all the audio setting options, some settings I found here in other forums but they didn't work and about jack yes it's only one side working.. and in the properties It shows that there is no jack information available. and can u help me where I can find User CP ..
  4. Posts : 3,141
    Have you made sure all the connections to the card are snug and card seated properly? Latest driver? Could be a bad card.
  5. Posts : 8,135
    Most sound have a Left/Right balance control in the Volume Control Panel. If it's set for one side you will only get one side (channel).
  6. Posts : 1,614
    Windows 7 Pro & Vista Home Premium
    The UserCP is at the very top of the page to the right of New Posts
  7. Posts : 4,280
    Just to visualize the afore mentioned post. It's located here. Audio problem-usercp-1.png
  8. Posts : 1,614
    Thanks, my suggestion pails in comparison
  9. Posts : 4,280
    No problem your welcome to use it in the future if so desired. Fabe
  10. Posts : 1,614
    Let's see if it works:
    Yep, excellent
