Windows 7: Realtek hd problem..headphones work as speakers..
08 Dec 2009   #11
SORYNXRO
win 7
Yes i rebooted.Now i figured out that i have sound on headphones only when i let windows install Microsoft High Definition Driver ,when i'm installing realtek hd 2.37 i don't have sound on internal speakers or headphones.Any ideas why ?
08 Dec 2009   #12
SORYNXRO
win 7
Why it turns to spdif when i unplug my headphones? It should turn to Rear Left and Rear right where i think my internal speakers are connected
08 Dec 2009   #13
SORYNXRO
win 7
I finally have sound in headphones with new Realtek 2.38 drivers.Speakers no sound ,but now when i unplug my headphones i can hear a fade sound in internal speakers for few seconds....
08 Dec 2009   #14
Jonathan_King
Windows 7 Professional x64
Did the sound ever work on your laptop?
08 Dec 2009   #15
SORYNXRO
win 7
yes..is working now only when i make a sound test with Microsoft high definition driver and headphones plugged in ..
08 Dec 2009   #16
SORYNXRO
win 7
I said earlier that i had my motherboard repaired ,audio chip replaced and after than i have sound only in headphones with Microsoft High Definition driver and in internal speakers when i run a sound test..it is a picture on my first post
08 Dec 2009   #17
SORYNXRO
win 7
If i put a new sound card in pci express socket will i have sound on internal speakers?
09 Dec 2009   #18
elliottjoey
windows7 32bit
i have same trouble downloaded new realtek driver and now i dond have sound manager is there a way to just download the manager.
09 Dec 2009   #19
Jonathan_King
To the OP: who replaced your sound chip? Uncle Frank, who knows all about computers, or the manufacturer/OEM?
10 Dec 2009   #20
SORYNXRO
win 7
to elliottjoey: no u can't download only the sound manager ..i think that u haven't installed drivers properly.follow the instructions carrefully
to Jonathan_King: No ,sound chip was replaced by a laptop service but i think they made a mistake ..initially i had an ALC268 and now Everest detects an ALC888s witch i think that is not compatible with my MB.I talked with the guy from service and he is sure that he replaced with an ALC268 ..he said that i can check if i take a look on my MB.Anyway i m stuck with headphones sound only on Microsoft drivers unless is there a way to redirect somehow sound from headphones to internal speakers by regedit or software.
Realtek HD Audio Problem: Headphones appear as "Speakers"
Dear all, my speakers do work. When i plug in my headphone at front the speakers get replaced, means I head everything through the headphone. Headphones themselves aint shown under "Sound": It appears that both, speakers and headphones are used as one source for audio-out. However, I...
USB Headphones showing as speakers & Realtek not recongising either.
So as the title says, I recently built a new computer and I've had many problems regarding sound issues. Firstly, Realtek HD audio manager doesn't recognize my USB headset (sennheiser U320 gaming) OR my logitec headset as a device. The only thing it recognizes are my audio jack speakers. However,...
Sound card problem - headphones work, notebook speakers don't
Hi all, I just bought an old Toshiba A210 laptop and I'm dealing with a couple of (minor) problems. As the title says, I've tried every conceivable control, I can't get any sound from the speakers. No hissing sound, nothing, completely silent. Headphones work fine though. I checked device...
realtek audio not detecting speakers or headphones.
I have an Asus M4A89TD pro / usb3 that has Realtek audio onboard. I have just finished my build and have never been able to get any sound from any of my IO ports. None of the ports recognize anything that I plug in (i only have 2 sets of 2.1 speakers, one uses a single light green jack and the...
Can I have speakers & headphones both working in Win 7 + RealTek?
Before building a new PC, I had a simple solution in having headphones (with a MIC)and my speakers working at the same time. I put a 2-1 splitter in the back of my machine, and had the speakers/headphones running off one connection. Now, I have built a fancy new system, which has headphone...
Twitter Facebook
