Realtek hd problem..headphones work as speakers..
Page 1 of 3 123 LastLast
  1. Posts : 12
    win 7
    HELLO,
    I have a wired problem with realtek hd r237 windows 7 drivers:
    I don't have any sound on laptop's internal speakers but i can hear in headphones.In PLAYBACK DEVICES headphones are detected as speakers and when i unplug them sound automatically turns to SPDIF- no sound on internal speakers.
    If a make a sound test (with headphones pluged in) whith Quadraphonic selection i can hear FL in my left headphone ,FR in my right headphone,RL in left internal speaker and RR in right internal speaker.
    This is really frustrating ..help!!
    Attached Thumbnails Attached Thumbnails Realtek hd problem..headphones work as speakers..-headphones-connected.png   Realtek hd problem..headphones work as speakers..-headphones-out.png   Realtek hd problem..headphones work as speakers..-test-sound.png
  2. Posts : 13,354
    Windows 7 Professional x64
    Can you set the default device to your speakers when your headphones are not plugged in?
  3. Posts : 12
    win 7
    No i can't
  4. Posts : 13,354
    Go to Control Panel>Device Manager and see if there are any yellow icons.
  5. Posts : 12
    win 7
    Done that -nothing.Already tried several driver versions..the newest works best,at least i have sound in headphones
  6. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Have you tried using the Realtek HD Audio Manager to see if you can correct the problem from there?
  7. Posts : 12
    win 7
    From what i can see REALTEK HD 237 DRIVERS dosen't have an audio manager aplication.I installed older drivers that have that and i cannot hear anything in speakers or headphones
    I had my motherboard repaird last week and audio chip replaced but still the same problem
    This is what Everest tells me:
    Windows Audio
    Device Identifier Device Description
    midi-out.0 0001 001B Microsoft GS Wavetable Synth
    mixer.0 0001 FFFF Digital Audio (S/PDIF) (High De
    wave-out.0 0001 FFFF Digital Audio (S/PDIF) (High De
    PCI / PnP Audio
    Device Description Type
    Realtek ALC888/1200 @ nVIDIA MCP67/68 - High Definition Audio Controller PCI
    HD Audio
    [ nVIDIA MCP67/68 - High Definition Audio Controller ]
    Device Properties:
    Device Description nVIDIA MCP67/68 - High Definition Audio Controller
    Device Description (Windows) High Definition Audio Controller
    Bus Type PCI
    Device ID 10DE-055C
    Subsystem ID 1025-0126
    Revision A1
    Hardware ID PCI\VEN_10DE&DEV_055C&SUBSYS_01261025&REV_A1
    [ Conexant D330 ]
    Device Properties:
    Device Description Conexant D330
    Device Description (Windows) HDAUDIO Soft Data Fax Modem with SmartCP
    Device Type Modem
    Bus Type HDAUDIO
    Device ID 14F1-2C06
    Subsystem ID 14F1-0000
    Revision 1000
    Hardware ID HDAUDIO\FUNC_02&VEN_14F1&DEV_2C06&SUBSYS_14F10000&REV_1000
    [ Realtek ALC888/1200 ]
    Device Properties:
    Device Description Realtek ALC888/1200
    Device Description (Windows) High Definition Audio Device
    Device Type Audio
    Bus Type HDAUDIO
    Device ID 10EC-0888
    Subsystem ID 10EC-0888
    Revision 1002
    Hardware ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_10EC0888&REV_1002
    Audio Codecs
    [ AC-3 ACM Codec ]
    ACM Driver Properties:
    Driver Description AC-3 ACM Codec
    Copyright Notice © 2005 by fccHandler
    License Information GNU General Public License
    Driver Features Dolby Digital AC-3 codec for Windows ACM
    Driver Version 1.28
    [ Fraunhofer IIS MPEG Layer-3 Codec (decode only) ]
    Driver Description Fraunhofer IIS MPEG Layer-3 Codec (decode only)
    Copyright Notice Copyright © 1996-1999 Fraunhofer Institut Integrierte Schaltungen IIS
    Driver Features decoder only version
    Driver Version 1.09
    [ LAME MP3 Codec v0.9.2 - 3.98.2 ]
    Driver Description LAME MP3 Codec v0.9.2 - 3.98.2
    Copyright Notice 2002 Steve Lhomme
    License Information LGPL (see gnu.org)
    Driver Features only CBR implementation
    Driver Version 4.00
    [ Microsoft ADPCM CODEC ]
    Driver Description Microsoft ADPCM CODEC
    Copyright Notice Copyright (C) 1992-1996 Microsoft Corporation
    Driver Features Compresses and decompresses Microsoft ADPCM audio data.
    Driver Version 4.00
    [ Microsoft CCITT G.711 A-Law and u-Law CODEC ]
    Driver Description Microsoft CCITT G.711 A-Law and u-Law CODEC
    Copyright Notice Copyright (c) 1993-1996 Microsoft Corporation
    Driver Features Compresses and decompresses CCITT G.711 A-Law and u-Law audio data.
    Driver Version 4.00
    [ Microsoft GSM 6.10 Audio CODEC ]
    Driver Description Microsoft GSM 6.10 Audio CODEC
    Copyright Notice Copyright (C) 1993-1996 Microsoft Corporation
    Driver Features Compresses and decompresses audio data conforming to the ETSI-GSM (European Telecommunications Standards Institute-Groupe Special Mobile) recommendation 6.10.
    Driver Version 4.00
    [ Microsoft IMA ADPCM CODEC ]
    Driver Description Microsoft IMA ADPCM CODEC
    Driver Features Compresses and decompresses IMA ADPCM audio data.
    Driver Version 4.00
    [ Microsoft PCM Converter ]
    Driver Description Microsoft PCM Converter
    Driver Features Converts frequency and bits per sample of PCM audio data.
    Driver Version 5.00
  8. Posts : 9,582
  9. Posts : 12
    win 7
    I just installed Realtek HD audio manager from 2.37 drivers and now i have no sound in headphones or speakers
    I tried different settings in audio manager nothing worked ..still spdif when i have my headphones unplugged and speakers when i plug them
  10. Posts : 13,354
    Did you reboot after you uninstalled?
