Media and FN keys problem
  1. Posts : 5
    Hi, I have a problem with function keys on my Acer Aspire 5535.
    When I press the vol up/ vol dwn key it works just fine but it should show a message on the screen like on XP or Vista.
    The sam thing is with function keys...
  2. Posts : 28,845
    Win 8 Release candidate 8400
    Hi and welcome
    You can use the same drivers you did in vistsa if you install them in compatibility mode.
    What drivers are you using now?
    Ken J+
  3. Posts : 5
    i did use the same drivers in compatability mode, and if i install the older version of the drivers half of the keys work (vol up/dwn, mute, turn off the touchpad...), and if install the new version downloaded from acer.com the other half works... i really don't get it.
