external card, and front audio on pc case
  1. Posts : 512
    windows 7 professional 64 bit
    is it possible to hook those 2 up??? or is that for the onboard audio only???
  2. Posts : 1,607
    Windows 7 x64 finally!
    Hi sotorius, if your card has such connections, I don't see why not:
  3. Posts : 512
    ok so those same type of connections have to be on the external sound card, the same as the motherboard???
  4. Posts : 1,607
    I really never tried it, but I suspect that you won't be able to connect if they aren't
  5. Posts : 3,960
    W7 x64
    I've never seen AC97, or Azalia HD, pinouts on external (USB) soundcards. I doubt it will prove possible to use the case front ports without a ridiculous amount of custom adaptation work.
  6. Posts : 512
    well crap i wouldn't really say external.... excuse me if i miss lead you guys i meant like a pci sound card
  7. Posts : 1,614
    Windows 7 Pro & Vista Home Premium
    You'llneed this codec"
    AC'97 Audio Codec - Download
  8. Posts : 512
    i would like to find a card that allows me to put my front audio jacks cause i think this asus xonar d2 that i have does not have the connections for that.
  9. Posts : 1,607
    sotorius, what do you need to plug into the front panel? I think you can plug everything to the Xonar X2 in the back, you shouldn't need to use the front, which you can leave plugged to the motherboard
  10. Posts : 512
    well i have speakers and an external mic and i also have a headset that has 2 3.5 jacks for headphones and mic.
