Sound Only From Front 2 speakers
  1. Posts : 38
    xp pro Win 7
    I have A Creative Inspire 5.1 hooked up to my Realtek sound on board via S/dif digital optical, have tried latest drivers, tried different settings, only 2 spekers work.
    SOME Integrated Audio systems have a digital output but that output is only two channel stereo. As that is all you are getting it may be your sound is 5.1 surround in analog but not digital.
  3. Posts : 38
    xp pro Win 7
    How do i figure this out, my system is a dual boot, in XP I get all 5 speakers.
  4. Posts : 1,508
    Lion
    did you setup speaker in win 7 for 5.1 surround?
  5. Posts : 38
    xp pro Win 7
    Yes I did
  6. Posts : 1,508
    Lion
    Creative CD does come with a testing software to check whether the speakers are properly setup. Have you tried it? If that software is not available with you, I believe you can download it from creative.
  7. Posts : 2
    WIN10 junk & WIN7 PRO 64bit
    Also had this problem, heres how I fixed it...
    Driver used (SB24_VTDRV_LB_1_04_0090.exe) available from creative.
    Install and when done go to Control panel, Manage audio devices.. This should display a sound window with devices listed, select SB live and in bottom left corner click configure. Should be pretty much self explanatory after that.
  8. Posts : 38
    xp pro Win 7
    I am not using a sound blaster card though.
