No sound when playing DVD
  1. JPF
    Windows 7 starter
    Hi all
    i'm having problems with my new webbook. the sound is working in general, wma files play and I can hear sound when streaming etc but when I try and play a dvd I get no sound. i thought it was the external dvd player so I reinstalled the driver with the windows 7 driver, installed the latest driver for the DVD software for Win 7 no luck, then someone suggested DivX so I installed that still no luck. on the DivX website it suggests that you install this software to see if you have the correct codec, did that and it says i have the correct codec installed to play the specific file, (see here DivX Support)
    so while looking here i read about issues with realtek drivers so I installed the latest driver for win 7 I thinkn its R2.37 and still no luck.
    Is there some setting in the Sound Manager that i need to adjust.
    any healp at all is appreciated as I cant take much more of this thing!!
    JPF
  2. Posts : 4,772
    Hi JPF, Welcome to SF,
    You can try something that might work
    Go To Control Panel > Hardware and Sound > Sound > Right click on Speakers > Properties > Advanced > Uncheck : "Allow applications to take exclusive control of this device".
    Or
    You could download and install VLC Media Player try to play in that one
    Hope that helps
  3. Posts : 8,870
    This setting seems to have an effect on DVD's when they aren't playing sound. Switching to DVD quality 48000 seems to help sometimes.
    Attached Thumbnails Attached Thumbnails No sound when playing DVD-application-control-device.png
  4. Posts : 6,879
    Win 7 Ultimate x64
    Just in case anyone missed it JPF has Windows 7 Starter as his OS and it comes with one very large limitation regarding what he is trying to do,
    Let?s talk about Windows 7 Starter - Windows 7 Team Blog - The Windows Blog
    It is important to note that Windows 7 Starter still includes only a subset of the features offered in the higher editions of Windows 7 such as Windows 7 Home Premium, Windows 7 Professional and above. Windows 7 Starter does not include:
    • Aero Glass, meaning you can only use the “Windows Basic” or other opaque themes. It also means you do not get Taskbar Previews or Aero Peek.
    • Personalization features for changing desktop backgrounds, window colors, or sound schemes.
    • The ability to switch between users without having to log off.
    • Multi-monitor support.
    • DVD playback.
    • Windows Media Center for watching recorded TV or other media.
    • Remote Media Streaming for streaming your music, videos, and recorded TV from your home computer.
    • Domain support for business customers.
    • XP Mode for those that want the ability to run older Windows XP programs on Windows 7.
    That said the VLC that Capt. Jack linked to should work. If not will have to look into some other DVD playing capable software.
  5. JPF
    Windows 7 starter
    thanks for the advice guys. only getting to check back now, I'll try and download the VLC software and if that doesn't work maybe try and install windows XP which is what was advertised with the web book initially but when I got home discovered win 7 was installed!!
