Windows 7: Conexant AC-97 Audio HELP, PLEASE!
27 Dec 2009   #11
aem
Windows 7 Ultimate 64Bit
It's not a very good way to edit the .inf file and put your device id into it. the drive was evidently made Conexant AC-Link Audio in mind, yes it works but doing this way might also work for many other "compatible drivers". Utimately, how your actual device and this driver will play out, will be evident down the track.
27 Dec 2009   #12
Soufiane
Windows 7 Ultimate 64-bit
Quote   Quote: Originally Posted by aem View Post
Thanks alot aem for the clarification, I appreciate it. So do you think there is a better idea for this issue, I mean instead of modifying the .inf file and all this process, is there a better way out to this. as far as my sound card is concerned, it seems working ok as you see on these pics ...
[img=http://img24.imageshack.us/img24/6208/81513245.th.jpg]
[img=http://img136.imageshack.us/img136/2999/15421502.th.jpg]
[img=http://img710.imageshack.us/img710/7678/16695630.th.jpg]
27 Dec 2009   #13
aem
Perhaps no other ways if you have search to the end of the internet and still can't find a working driver. Not every new devices have drivers that are 100% immediately compatible with it. Hence you have what's it's called compatible drivers (near match), as apposed to actual drivers. There is also a "time" issue between vendors and manufacteres of new devices. Often with new hardware, vendors often don't wait for manufacturers to code up new drivers, and so they "packaged" existing drivers they think will work.
Just leave it for now and see how you go.
27 Dec 2009   #14
Soufiane
Thank you very much aem for everything, you are very kind, I appreciate it, good luck with everything! :)
conexant HD audio not working windows 7 64 Bit
I have encountered issues with Conexant HD Audio driver. When I install driver there will be no sound and when I uninstall it there will be sound. Here I am attaching my computer specifications. Thank You. http://i.imgur.com/i1Lvffo.png
Mic Problem (Conexant HD Smart Audio 221)
Hi, Ive been looking for a solution for so long ! Looked everywhere and no answers so i am posting here. My problem is that when i plug in an external mic, it does not work but the internal mic does work. I am running HP G60-348CA Windows 7 Conexant HD Smart Audio 221 (Date released:...
conexant ac-link audio for window 7
Hello,I reinstall my window 7 ultimate, but after installing sound was lost. After uninstalling I tried to update the driver from the device manager but it still not working. but the driver is already in my PC the driver manufacturer is conexant the driver version is 6.14.10.597 my pc is...
Drivers
I have Windows 7 beta loaded on my HP Pavilion zd8000 portable, so far everything seems to be fine except the audio. This computer has a Conexant AC-97 audio chip. The sound is coming out like it is going through a reverb unit set on high. Everything sounds like a bad stutter. Once in a while...
Conexant AMC Audio
Hi, I am looking for the windows 7 drivers for Conexant AMC Audio. Toshiba Satellite L20 PCI\VEN_1002&DEV_4370&SUBSYS_FF311179&REV_02 PCI\VEN_1002&DEV_4370&SUBSYS_FF311179 PCI\VEN_1002&DEV_4370&CC_040100 PCI\VEN_1002&DEV_4370&CC_0401
Drivers
Twitter Facebook
